Old 03-12-2008, 02:56 PM   #1
chixwithtrix
chixwithtrix is an unknown quantity at this point
Stock SR20DET turbo install
So my friend bought an SR20det powered S13, but the previous owner did not have enough $ to buy exhaust and intercooler to install the stock turbo so it is currently NA.
My friend wants to install the turbo himself to save $$, which pretty much means that we all get to sit there scratching our heads when something goes wrong. So...what I'd like to know is any pointers, how to's, diagrams, recipes, etc that could help install the setup. We already bought an exhaust and an Ebay FMIC kit.
Since its not my car I'm not familiar with it or what cooling and oil lines, fittings to the turbo the previous owner had. If we do need lines/fittings, are any available locally from an Auto parts store or or do we have to order them?
here are some pics of what he has on the turbo...what do we need to get the stock turbo setup on it?
Edit: sorry, for some reason the pics didn't upload
chixwithtrix is offline   Reply With Quote
Old 03-12-2008, 03:01 PM   #2
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
I don't see any pics, and also, lots of this information your requesting is FAQ.
duffman1278 is offline   Reply With Quote
Old 03-12-2008, 03:05 PM   #3
Beebo
Beebo is an unknown quantity at this point
yah the pics dont work. everything should be pretty self explanatory, just bolt it all up. make sure the gaskets are good, and you have a vaccuum/boost line going to the wastegate actuator.
see if you can find a factory service manual for the sr20.
where in texas are yah from? just curious. im in plano.
Beebo is offline   Reply With Quote
Old 03-12-2008, 03:14 PM   #4
chixwithtrix
I know, I apologize for another "help with turbo setup" kind of thread...I searched through a few forums and posts, but most of them were of people who were familiar with their setup.
Since my 240 is a stock KA I'm not familiar with what fittings and hoses are needed for the stock SR20det and whether the previous idiot owner included them, thats why I included the pictures to see if you guys could see if all of the parts where there to install or not. If all of the parts are there it hopefully will be pretty straight forward.
I'm in Austin...if you drift you should come out to the Mineral Wells drift events that are held every month. You should be a lot closer than I am to there being north of Dallas. They're pretty laid back and cheap @ $40
Old 03-12-2008, 03:55 PM   #5
Sileighty_85
Sileighty_85's Avatar
So hes been rockin a DET as a DE? well first off ditch the stock coolant and water hardlines and get some Circuit Sport SS Lines from EnjukuRacing.com for like 120 bucks, every one will say get Taka Line but them shits are expensive, Im using Curcuit Sport Lines on mine and I've never had a problem, as far as finding out where the line go, once you crack open the capped off ports for oil and water it will be obvious, the water feed line will be on the back if the head, Its a small skinny tube line, If I remember right the oil feed is the bottom of the block and the coolant is right above it
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-12-2008, 04:56 PM   #6
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
hands down get the CS stainless lines, they will make your life easier. and hey, while you have the turbo out, check for in/out and side/side shaft play.
clark is offline   Reply With Quote
Old 03-12-2008, 05:01 PM   #7
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
driftcar.net has some factory service manuals available for the public, i though that they were helpfull a little...
handinpants is offline   Reply With Quote
Old 03-12-2008, 05:07 PM   #8
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
so the car runs fine without the turbo?
i thought it would run funny ..and need a different ecu or tune???no???
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 03-12-2008, 05:23 PM   #9
Sileighty_85
One of my buddies crunched his Side Mount on his 180SX in an accident, and we duct taped his MAF to his TB, drove fine except for comming to stops, then it would die due to the IACV not pulling through the MAF lol
I got pics of it at home lol
後輪駆動車1番
1986 SR86 - 200ish
Old 03-12-2008, 05:41 PM   #10
chixwithtrix
yeah, its a det without the turbo...it runs fucking rich, has a ghetto ass exhaust that leaks and has absolutely no power, but runs the stock turbo map. My KA beats it with a stick w/o the turbo
As far as the lines, so from the photos does it look like it has all of the stock lines needed to put it back on? I'd go for the SS lines, but I'm not sure if my buddy who owns the car will...
Old 03-12-2008, 05:45 PM   #11
Sileighty_85
No surpirse there lol
yeah its got all the lines but for install, unless yall are very carful there is a high chance you will strip the threads in the Block when installing the Banjo Bolts for the oil and coolant, The Block is Aluminum So it dosnt take much to strip the threads
So tell ur buddy to save him self from pullin the engine and a HUGE Head ache and get the SS Lines
後輪駆動車1番
1986 SR86 - 200ish
Old 03-12-2008, 08:50 PM   #12
chixwithtrix
In the first photo, where does that line go on the engine?
In the second photo, isn't that supposed to be part of a banjo fitting with a hole in it..? That is a solid bolt and I if it needs to be for a banjo I need to know the size and thread
Old 03-12-2008, 08:57 PM   #13
Sileighty_85
first pic is the coolant feed hose its inbetween the back of the head and the fire wall, look for a rubber hose pluged with a bolt in it,
Second pic is the coolant drain for the block leave it in there
that bolt with the #8 stamped on it is the oil feed for the turbo I believe
後輪駆動車1番
1986 SR86 - 200ish
Old 03-12-2008, 10:15 PM   #14
chixwithtrix
Cool
yeah, you were right about the #8 bolt being the oil feed...only problem is they replaced it with a solid bolt instead of the banjo. So what thread and size would I need for that?
Old 03-14-2008, 05:37 PM   #15
chixwithtrix
Alright, I found the bolt size and had to order one from a local BMW dealer since we found the part # from them. For anyone who may need to know this it is a 12mm 1.5 pitch banjo bolt.
Anyway, hopefully last question - where does this hook up/go to?
Old 03-14-2008, 05:43 PM   #16
Sileighty_85
sorry I could have told you I "Think" its the same as the 300ZX,
But thats the Waste Gate Actuator you run it to a vacuume source on the cold pipe, but you need a boost contoller in between the W/G and the cold pie or it will run less than stock boost, I think its 7psi?
後輪駆動車1番
1986 SR86 - 200ish
Old 03-14-2008, 06:39 PM   #17
duffman1278
Its not the cold pipe you need to run it too, its the hotpipe. Your boost controller goes between the hotpipe and the waste gate. If you have no boost controller just connect it straight through.
Old 03-14-2008, 06:47 PM   #18
Sileighty_85
OEM configuration is the cold pipe, theres a nipple right after the Side mount.
But yeah if no B/C just connect it straight from a vacuume source
I got mine running off of the throttle body, no problems
make sure you ziptie the vacuume hose on or they'll pop off and you'll blow the turbo
後輪駆動車1番
1986 SR86 - 200ish
Old 03-14-2008, 07:15 PM   #19
chixwithtrix
He has no boost controller, so if I have this right...we just find a vac line, clip it, run a T from it to the WG and we're good?
Old 03-14-2008, 07:22 PM   #20
Sileighty_85
correct, dont forget the zip ties :P
後輪駆動車1番
1986 SR86 - 200ish
