Old 02-03-2003, 11:54 AM   #1
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
LSD j30 vs. s14
Anybody know the benefits and draw backs between a j30 LSD or an s14 stock LSd? I don't mean in terms of install either. I strictly mean regarding performance? thanks, joe
burgy240 is offline   Reply With Quote
Old 02-03-2003, 12:00 PM   #2
AKADriver
AKADriver's Avatar
3.916:1 gear ratio instead of 4.083:1.
4% loss in mechanical advantage... 4% worse acceleration.
Aside from the gear ratio it should be exactly the same (same LSD response).
Old 02-03-2003, 12:19 PM   #3
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Seeing as you have an SR, you might consider it more like 4% more gear in every gear. I know a fast SR w/ a typical KA final drive sucks.
Ryan will correct me if I'm wrong, but I think the j30 is the same ratio as the SR.
HippoSleek is offline   Reply With Quote
Old 02-03-2003, 01:11 PM   #4
AKADriver
AKADriver's Avatar
5-speed SR cars had the 4.083:1 ratio, same as the KA.
The extra speed in each gear might be worth it if you're frying the tires off the line right now.
Old 02-03-2003, 03:58 PM   #5
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
so explain why my 1997 J30t rear end had 4.08 stamped into the RING gear......i have been asking about this for a long time
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 02-03-2003, 07:47 PM   #6
HippoSleek
HippoSleek's Avatar
Unhappy DOH
Why. Why. Why. I never get this one right. I distinctly remember telling someone the USDM and JDM lsd's were the same... and was promptly pointed to heavythrottle saying they weren't. I backed up the search on FA and agreed w/ heavythrottle. Since the search is broken and Jeff and Yury don't have any diffs on their site, I can't refute this. Ugh.
Old 02-03-2003, 09:09 PM   #7
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
didn't different years of the j30 have different gears? like a 95 had a 3.916:1 gear ratio?
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 02-04-2003, 01:48 AM   #8
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
ok guys most if not all J30's came with 3.916 which rounds off to 3.92 gears . I have never heard or seen a J30 diff with 4.08 .
Ok now on to the Japanese side of things . CA18 powered cars supposedly came with lower gears than are in our cars here stateside.
NA SR cars came with 4.08 . S14 SRdet cars and S15 SRDET cars came with 3.70 gears just like the Z32 VG30DETT cars. I know this because I was researching it about a year ago. Now on the S13's it seems that some SRDET cars did come with 4.08's but there where also some that came with 3.70 gears. I think it all depended on the year.
FWIW if you are running a SR you are better off with a 3.92 or 3.70 gear rear end because it will indeed keep you in boost longer due to the fact that it takes a bit longer to rev through your gears.
Which means that though its taller you will still pick up acceleration due to being under boost longer.
this is why a NA Z32 diff has 4.08 gears like our car and the Z32 Turbo diff has 3.70 .
New Video
Buy my mounts!
Old 02-04-2003, 07:56 AM   #9
AKADriver
AKADriver's Avatar
On all the S13 and S14 5-speed SR20DET clips I've ever seen, the axle code listed on the firewall tag was "RC40" indicating a ~4.0:1 R200.
Nissan axle codes:
R = RWD
A = R160, B = R180, C = R200, D = R230
## = ratio rounded to the nearest tenth
If you're pulling a diff from a J30 and you're unsure of the ratio, RC39 will be the 3.916:1 box, RC40 will be the 4.083:1 box.
Automatic S13/S14 SR20DETs had the 3.916 ratio.
The 3.692:1 ratio was included with the six speed in the S15.
Here's some proof:
I could find more... anyway, find a shot of an S13 or S14 firewall tag indicating an SR20DET, a manual transmission (FS5W71C), and an axle other than 'RC40', and I'll believe it.
- Ryan, FIREWALL TAG NAZI!
Edit: just an aside... the CA18DET ratio was indeed 4.363:1, manual or automatic. Their tags say 'RC43'.
Old 02-04-2003, 09:35 AM   #10
HippoSleek
HippoSleek's Avatar
ATTN MODS - can someone change this guy's status to "Firewall Tag Nazi"? That would own.
Okay, my problem is that I am now having a fundamental issue with multiple information sources. Your info is always good and firewall tags are awfully tough to refute BUT, so is heavythrottle.
Query: did the SR20DET auto come with a 3.9 or 3.7 ratio?
Query2: why can't the Japanese round numbers like the rest of the world?
Old 02-04-2003, 10:25 AM   #11
AKADriver
AKADriver's Avatar
Q1: 3.916 by every source I've seen.
Q2: I guess it's really truncated more than rounded... going to four digits is just my own pedantic self
Old 02-04-2003, 11:13 AM   #12
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
hehehe thats whats under my S14 now! well equipped with a NISMO LSD let me tell you... 1st gear? its useless
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 02-04-2003, 02:05 PM   #13
RedSuns
RedSuns's Avatar
i am betting that the junkyard mis-labeled it......because i have been cloked at 85 and my speedo was dead on......
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
Old 02-05-2003, 11:33 AM   #14
burgy240
burgy240's Avatar
So the final decision is that it is better for me to go with the j30 for my SR powered s14 right? I belive that this is the way I will go after all unless someone can prove the other case. thanks all.
Old 02-05-2003, 01:10 PM   #15
AKADriver
AKADriver's Avatar
There's no proof one way or the other, it's all preference and what you plan to use the car for.
