Old 03-19-2008, 09:29 PM   #1
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
SR S13 SR running rich
I just replaced my old rusty gas tank and finally got my SR to start. She idles fine around 800ish but smokes like hell and smells like gas. I'm running stock injectors and FPR, 255 walbro, and T25.
Pulled code 11, which is camshaft pos sensor. So I'm guessing I got the base timing wrong. I just lined the crank up with the second notch on the left and with the dots on the cams. I dont think my timing chain has the different colored guide links. What do you guys think?
Oh, my starter is starting to grind and I get this weird grinding noise when I press the clutch. Should I have gotten a new pilot and throwout bearing when I did the swap?
Last edited by flip3d; 03-20-2008 at 08:39 AM.. Reason: cam pos sensor not crank. d'oh!
flip3d is offline   Reply With Quote
Old 03-20-2008, 12:23 AM   #2
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Crank position sensor is different from the Camshaft Position sensor. Unless you mixed up the 2 because I didn't search up that code.
duffman1278 is offline   Reply With Quote
Old 03-20-2008, 01:18 AM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
get a fuel pressure regulator. sard or aeromotive
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 03-20-2008, 08:40 AM   #4
flip3d
flip3d's Avatar
My FPR is fine. I have a fuel pressure gauge and everything is within spec.
Old 03-20-2008, 02:12 PM   #5
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
check the cts, check for boost/vac leaks, check your maf, check to make sure your getting proper amount of spark from your coils
"I am Norwegian, and are not familiar with your urban words :P"
jskateborders is offline   Reply With Quote
Old 03-20-2008, 03:23 PM   #6
flip3d
flip3d's Avatar
Hah. Nevermind. I found the problem. One of my injector O-rings finally gave way.
So new o-rings, new plugs, and im back on the road
Code 11 only beacause I was cranking without the CAS plugged in.
