Old 03-25-2008, 10:16 PM   #1
RPS1392
RPS1392's Avatar
RPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura about
How to: Fix you clutch hard line for good.
Today I tackled the assembly and bleeding of the clutch line and slave cylinder. This is part of my on-going attempt to turn my 1992 240sx into a 180sx. The entire build thread can be found here:
http://www.zilvia.net/f/showthread.php?t=182565
I'm not sure what the two foot loop of hardline connected to my clutch line is for, but this is how I corrected it.
I took a spare section of line from the front clip, and measured out how much I would need.
What it looked like when I started.
A new end was needed after cutting the line.
And the end result.
RPS1392 is offline   Reply With Quote
Old 03-25-2008, 10:17 PM   #2
articdragon192
articdragon192's Avatar
You could have just removed the whole dampener and just ran the hardline straight into the slave cylinder.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 03-25-2008, 10:21 PM   #3
RPS1392
RPS1392's Avatar
Ya, but I like the idea of retaining the flexible line between the body and the transmission to absorb vibration/movement.
Old 03-25-2008, 10:24 PM   #4
scooz14
scooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura about
i think he meant you could get rid of that copper block. its completely useless
scooz14 is offline   Reply With Quote
Old 03-25-2008, 10:26 PM   #5
Kurai Shimo
Kurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to allKurai Shimo is a name known to all
i just bent the hardline around straight into the soft line leading to the clutch slave. , no real need for that 4 inch section of line with the union bolted to the frame rail, its just another place where fluid can leak from. but that does look really clean. alot cleaner than most any ive seen for sure.
Kurai Shimo is offline   Reply With Quote
Old 03-25-2008, 10:26 PM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
removing the damper ftw. it's entirely useless, and the clutch pedal feels way more direct without it.
and not to nitpick, but you can't convert a 240 to a 180 any more than i can convert a pineapple into a calculator.
but excellent build thread tho! looks nice!
Old 03-25-2008, 10:27 PM   #7
articdragon192
Oh whoops, I mean the hardline off the master straight into the rubber line.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 03-26-2008, 12:36 AM   #8
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
or just get a ss line from clutch mastet straight to slave
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 03-26-2008, 07:39 PM   #9
articdragon192
The only problem with that is that if it's not teflon coated, you'll have this nice long stainless line that's prone to vibrations. And vibrations with stainless lines = a saw in your engine bay.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 03-26-2008, 07:51 PM   #10
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
you did too much work IMO... also should have replaced that hard line with a SS line
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 03-26-2008, 08:19 PM   #11
Psycho 240 Freak
Psycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-known
If he wants to modify his car and call it a 180 then so f*cking what!! It's all technicalities. I'd understand if he was trying to convert it into a Ferrari.
Psycho 240 Freak is offline   Reply With Quote
Old 03-26-2008, 10:21 PM   #12
projectRDM
projectRDM's Avatar
Um, what? You did a writeup on something that we've been doing for over 15 years, but managed to add a step and make it harder to do? Now that's a new one.
You can bend the line 90 degrees around and screw it right into the rubber hose, eliminating the block completely. Just like the other 30 or so writeups found online.
As for this comment: you did too much work IMO... also should have replaced that hard line with a SS line.
The hardline is already steel. I think you meant the rubber hose.
FORMERLY R240NA
Old 03-27-2008, 12:01 AM   #13
vutony
vutony's Avatar
mine does have it, i didnt buy it till it was corrected
i do SR wiring
