Old 03-27-2008, 09:25 AM   #1
Maxstyle
Maxstyle's Avatar
Maxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond reputeMaxstyle has a reputation beyond repute
Brand new turbo does not spool after 80miles
I bought a brand new nissan S15 turbo. Now it won't spool. It's been working fine. I've only driven it 3 times in the past 2 weeks. Sucker just chooses not to spool this morning. Not understanding. Any Ideas? No Exhaust leaks. Drives like a smooth, no power NA.
Maxstyle is offline   Reply With Quote
Old 03-27-2008, 09:29 AM   #2
posdrift240
posdrift240's Avatar
posdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymore
Internal or External wastegate?
posdrift240 is offline   Reply With Quote
Old 03-27-2008, 09:34 AM   #3
Maxstyle
Maxstyle's Avatar
Brand new S15 internal T28 brand new from Nissan through reputable shop.
Old 03-27-2008, 09:36 AM   #4
txrxs
txrxs's Avatar
txrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfection
Blow off valve leaking?
Need more details on your cars setup.
DRIFTINDY
txrxs is offline   Reply With Quote
Old 03-27-2008, 09:48 AM   #5
Maxstyle
Maxstyle's Avatar
No leaks. Running HKS SSQV. No MAF (HKS VPC), FMIC, IC Piping seems to be in order. Exhaust has not leaks. Purchased all new Nissan origial nuts, studs and locking tabs.
Old 03-27-2008, 09:51 AM   #6
posdrift240
Check for a tear in your couplers! If you do not see any then you better be taking the turbo back off an inspecting it.
Old 03-27-2008, 09:57 AM   #7
91silvia
91silvia's Avatar
91silvia will become famous soon enough91silvia will become famous soon enough91silvia will become famous soon enough91silvia will become famous soon enough
Send a message via AIM to 91silvia
^^^what he said. Check your IC piping for any couplers that are blown off or leaking.
91silvia is offline   Reply With Quote
Old 03-27-2008, 10:23 AM   #8
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
Might want to pressure check the internal wastegate to make sure it's closing.
sean350z is offline   Reply With Quote
Old 03-27-2008, 10:56 AM   #9
txrxs
txrxs's Avatar
I had the same problem and I'm also running that piece of shit VPC. Double check your intercooler piping and couplers. Unlike MAF cars, VPC allows the car to run fine with a pipe off or leaking really bad.
DRIFTINDY
Old 03-27-2008, 11:04 AM   #10
Maxstyle
Maxstyle's Avatar
I thank you for your input. I do not appriciate the "piece of shit" comment. The VPC coupled with the GCC is one of the best tunning units for my setup. Anything else would just be over-kill. I don't need anything more and the car has run perfectly. I'll check it out a bit more tonight. Sucks that I have to be here at work instead of in my garage.
Old 03-27-2008, 11:08 AM   #11
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
make a boost leak tester out of PVC pipe and a fitting. hook that up to a air tank, slowly put more and more air in the system. You well hear the leaks(mostly wistles)
Also, take of your IC pipes and make sure your turbo is still spinning and that there is no oil in the charge pipes. Does your turbo make funny noises?
KA-T_240 is offline   Reply With Quote
Old 03-27-2008, 11:13 AM   #12
Maxstyle
Maxstyle's Avatar
Turbo is silent. Dead silent. That's what makes me nervous.
Old 03-27-2008, 11:59 AM   #13
McRussellPants
C-clip on the wastegate actuator fell off and now the wastegate is perma open.
McRussellPants is offline   Reply With Quote
Old 03-27-2008, 12:32 PM   #14
johngriff
johngriff's Avatar
Why don't you just take the intake off and check the shaft??
[email protected]
Old 03-27-2008, 12:45 PM   #15
Maxstyle
Maxstyle's Avatar
I will. This tread is just to help me formulate a checklist to make sure i don't miss anything when looking at it after work. Things like the clip, will all be checked out during lunch
Old 03-27-2008, 12:53 PM   #16
GSXRJJordan
GSXRJJordan's Avatar
My bet it a blown/torn intercooler coupling. If you had a MAF, you'd notice the car running like shit, but since you're running the VPC it will still run fine.
Even if the wastegate was stuck full open, he'd hear a little spool...
Old 03-27-2008, 02:17 PM   #17
!Zar!
!Zar!'s Avatar
It's a trick.
Your car doesn't have turbo at all.
I win.
Old 03-27-2008, 02:38 PM   #18
Maxstyle
Maxstyle's Avatar
^ you = the fail. JK. I miss boost.
Old 03-27-2008, 03:30 PM   #19
steve shadows
steve shadows's Avatar
most HKS electronics are pieces of shit.
At least in my experience.
Did you have the proper oil restrictor in line?
You might have siezed the CHRA.
The new Garrett GT turbos come with built in restrictors.
You might have gotten an older shevled nissan oem one.
not sure. might be worth checking into.
Have to checked with your bare hands to see if it is seized?
Like Me on FaceBook !
Old 03-28-2008, 11:32 AM   #20
KA-T_240
^yup. I do not think people posting stuff up here is going to help you. You need to go and physically examine the turbo and make sure its good.
Even if you had loose couplers or a major leak, you should still get some boost even 1-2 psi, unless you are missing a pipe or something like that. You would also be able to hear the turbo.
Old 03-28-2008, 11:34 AM   #21
Maxstyle
Maxstyle's Avatar
After installing new turbo and adding a few miles, Turbo needs to be retightened. I was an aware of that proc. and seem to have a large exhaust leak. Thanks so much for everyone's help.
Old 03-28-2008, 02:22 PM   #22
Def
The "turbo needs to be retightened?" I'm guessing you're talking about the turbine to manifold bolts? Wouldn't you hear an exhaust leak that loud?
Old 03-28-2008, 05:12 PM   #23
Maxstyle
Maxstyle's Avatar
Not loud. pulling it off tonight now that i finally have a chance.
Old 03-28-2008, 05:49 PM   #24
GSXRJJordan
If you use the locking tabs correctly, and use OEM (locking) manifold->head nuts, it shouldn't loosen. None of the T-bolts/hose clamps should loosen... I'm confused as to what came loose.
Good luck getting it all to go together and stay together
Old 03-28-2008, 05:57 PM   #25
steve shadows
yeah don't waste your money or time on thread lock
used tabs only
Old 03-28-2008, 08:29 PM   #26
s14alex
s14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of light
used tabs only
Yea
I have to fix mine now constantly
s14alex is offline   Reply With Quote
Old 03-28-2008, 08:35 PM   #27
Maxstyle
Maxstyle's Avatar
Got the tabs. All is well. thanks to all
Old 04-02-2008, 11:17 PM   #28
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
are you using locking nuts as well? new studs?
reccakun08 is offline   Reply With Quote
Old 04-03-2008, 12:12 AM   #29
GSXRJJordan
Doesn't matter if you use locking nuts or not, the nylon melts and the vibration loosens the nuts. For the record, new studs from a hardware store are often not of the same harness (OEM studs are '8' IIRC), and sometimes not better at all.
/threadlock plz.
Old 04-03-2008, 12:24 AM   #30
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
honestly I tack weld all the nuts on the turbo.
blu808 is offline   Reply With Quote
