Old 03-31-2008, 09:20 PM   #1
dwadia
dwadia is making his/her stupidity well-knowndwadia is making his/her stupidity well-knowndwadia is making his/her stupidity well-known
can i mount my s14 MAF vertically, just before the throttle body?
I think this would make for better overall fitment of my intake and IC piping. Is there any reason not to mount it vertically? And right before the throttle body?
If it's relevant, i have an s14 engine in an s13 chassis with a Blitz FMIC and stock s14 MAF.
dwadia is offline   Reply With Quote
Old 03-31-2008, 09:22 PM   #2
Nismoknightska-t
Location: Azusa, socal baby! why do i live this way?? it must be the money!
Nismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfection
Send a message via AIM to Nismoknightska-t
it does not matter where you mount it..
NismoKnights
Terrorizing Honda crews since 2003
ls2 powered kouki..all show and GO! putting it down on the streets and the track! LMAO V8
Nismokights on http://www.youtube.com/user/NismoKnights
Nismoknightska-t is offline   Reply With Quote
Old 03-31-2008, 09:34 PM   #3
dwadia
cool thanks.
Old 03-31-2008, 09:36 PM   #4
GSXRJJordan
GSXRJJordan's Avatar
That's not exactly true.
I know you didn't mention whether your 'S14 engine' was a SR20 or KA, but when you mount the MAF after the turbo, it's called a "blow through setup". Our MAFs are not designed to be run like this, (they're designed to be "pull through", aka mounted before the turbo) and it requires tuning to make it work right on the stock MAF or a Ford Cobra MAF (the more popular choice).
As far as vertical vs horizontal, that does not matter.
Old 03-31-2008, 09:46 PM   #5
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
but if you dont mount it far enough from the turbo you will get funny signals it has so far downstream but i cant recall the minimum amount
also you can hack your maf to be a blow through set up. people that do it either swear by it or quickly return.
bigOdom1 is offline   Reply With Quote
Old 03-31-2008, 09:47 PM   #6
slider2828
slider2828's Avatar
It does matter. As per mafs spec there MUST be 3" of straight pipe before and after the MAFS. Doesn't matter if you mount vertically or horizontally.
Turn and Burn!
Old 03-31-2008, 09:48 PM   #7
bigOdom1
bigOdom1's Avatar
i thought after the maf it had to be more than three inches
Old 03-31-2008, 10:55 PM   #8
slider2828
slider2828's Avatar
I think it could be, but I have heard 3"
Hey Big, you run SCCA? I see the SM sticker, why are you in SM and not DSP? I have SR Modded with Coilovers and I run DSP>
Turn and Burn!
Old 04-01-2008, 07:32 AM   #9
orion::S14
orion::S14's Avatar
Originally Posted by slider2828 View Post
...I see the SM sticker, why are you in SM and not DSP? I have SR Modded with Coilovers and I run DSP...
You're in the wrong class.
Any Nissan engine swap = SM...there is no other class that allows a SR swap. (EDIT: other than X-mod, and those wacko classes)
..or KA-T for that matter.
But, SCCA leaves classing up to the member, so they don;t have to correct you. Someday, someone who cares will be in DSP, and protest you.
[/offtopic]
- Brian
www.KA24DEvelopment.com
Old 04-01-2008, 09:03 AM   #10
projectRDM
projectRDM's Avatar
The general rule of thumb is 18". 18" away from the throttle body, 18" away from the turbo inlet.
FORMERLY R240NA
Old 04-01-2008, 09:55 AM   #11
slider2828
slider2828's Avatar
Thanks project..... but you do need certain amount of straight piping before and afte correct?
Turn and Burn!
Old 04-01-2008, 10:14 AM   #12
projectRDM
projectRDM's Avatar
Not really. The distance is to decrease turbulence, figure any bend will give the same flow no matter what it is.
FORMERLY R240NA
Old 04-02-2008, 10:52 AM   #13
greddyguy
greddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choices
I did an 89 ka-t with a blow through maf and it laid down 305whp. Maxed out the maf but it ran fine
greddyguy is offline   Reply With Quote
Old 04-02-2008, 02:28 PM   #14
projectRDM
projectRDM's Avatar
Which has absolutely nothing to do with the thread. Good job, you want a cookie?
FORMERLY R240NA
Old 04-02-2008, 03:15 PM   #15
dwadia
Oh shit, somehow i thought this thread got only one response and never looked at it till now!! Well, it's for an s14 sr20det, sorry if i wasn't clear about that.
I already ordered intake piping to accomodate the MAF just before the throttle body (vertically, starting just above the battery tray). Without measuring, it probably has 8"+ of straight pipe before it, an immediate 90-degree bend after it, and 14" or so total piping before the throttle body.
If i run it like this, is there any chance of damaging anything? The only 2 possibilities i can think of are if the MAF will be damaged by the blow-thru setup, or if it may somehow cause the engine to run lean. Are either of these possible? If it's safe, at this point i'd just figure nothing to lose, i can at least give it a try. What do you guys think?
