Old 04-05-2008, 12:21 PM   #1
OpHaScHiLlM
OpHaScHiLlM is making a name for him/her selfOpHaScHiLlM is making a name for him/her self
question about blacktop and coolent return
i just have a few basic questions hopefully someone can answer.
i recently got a "late model 95 blacktop" but it has a skinny o2 17mm??
the person before me had custom everything, he could of put a wrong one on maybe?? not sure, here is a pic of the front of the motor w/ fins
also ? about the coolant return line like which one is it? here are some pics.
there is that line that runs to the turbo that splits from the heater line, is that it? Or thats not it and....
this thing maybe coming down out of the turbo not hooked up to anything??
if it is where does it connect to the other side?
thanks
OpHaScHiLlM is offline   Reply With Quote
Old 04-06-2008, 05:10 PM   #2
OpHaScHiLlM
i found out its the 2nd pic one from the heater line, so whats the one in the 3rd pic and where does it connect...sorry for the stupid question but im trying to figure everything out.
Old 04-06-2008, 06:33 PM   #3
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
The pipe in the 3rd picture is the turbo oil return line.
It is connected to the block (you can see the fitting just to the right of the return line) via a small rubber hose that's heat wrapped.
HalveBlue is offline   Reply With Quote
Old 04-06-2008, 07:57 PM   #4
OpHaScHiLlM
thanks, you are referring to the one the oil return line is pointing at in front, an inch to the right attached to the engine(its not rubber or heat wrapped though)??
Old 04-06-2008, 08:04 PM   #5
HalveBlue
HalveBlue's Avatar
Correct.
What I'm saying is that the oil return is connected to that fitting via a rubber hose, and that hose is heat wrapped.
Old 04-06-2008, 08:21 PM   #6
OpHaScHiLlM
thanks a lot man
