Old 03-13-2008, 12:16 PM   #1
shmiddy
shmiddy's Avatar
ebay knock off intake manifold
has anyone, or is anyone using the e-bay knock off to the greddy intake manifold for the sr20? if so any problems with it or manufacuring defects??
i fully de-volved
Old 03-13-2008, 12:17 PM   #2
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Casting sucks but some people have cleaned it up with a dremel and says it works pretty good. Search.
flip3d is offline   Reply With Quote
Old 03-13-2008, 12:29 PM   #3
shmiddy
shmiddy's Avatar
im posting cuz i searched but thanx for the info. what do u mean by "cleaned it up" whats wrong with it?
i fully de-volved
Old 03-13-2008, 12:33 PM   #4
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
I got one
looks like shit, but it should work. inside could use some dremeling out of burs and shit, and if you care what the outside looks like, it could use a lot of smoothing.
Mine doesn't seem to leak though, so it's all good with me. If mine does develop a leak or something though, I'll probably just go real greddy.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 03-13-2008, 12:35 PM   #5
alexander500
alexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond repute
The seams in the casting have extra bits and pieces, you will want to use something to knock these off and smooth it out a little bet
alexander500 is offline   Reply With Quote
Old 03-13-2008, 12:41 PM   #6
shmiddy
shmiddy's Avatar
times are hard i dont think i can go for greddy right now. looks like a freddy intake manifold for me!!
have you guys had any problems finding a furl rail/ fuel injector set up to fit properly with the freddy?
i fully de-volved
Old 03-13-2008, 12:45 PM   #7
240trainee
240trainee's Avatar
I had to cut a couple tabs off the stock fuel rail, you don't use them all on the greddy
and your gonna have to fab up a throttle cable bracket.
Other than that, I think everything is good.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 03-14-2008, 09:02 AM   #8
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
I just finished installing one. Overall its ok but like mentioned, it does need work to be useable. The casting is rough inside and a tad bit rough outside. I cleaned mine up with a die grinder inside the ports as well as sanding down and rough areas and casting flash on the outside. Also my throttle body did not line up with the port when bolted on so again, more grinding was required. I should also point out that when I recieved it, there were metal filings in the intake from the holes being tapped. These manifolds really MUST be cleaned up before use - at best it'll look like crap, at worst you will kill your engine.
You will need to fab up a throttle bracket as well. I am using a SOHC throttle cable which, while a bit short (it runs across the valve cover), works fine.
Other than that, for $100 and about an hour of time I seem to have way less torque falloff up top and it makes changing the oil a whole lot easier.
"Genius may have its limitations,
but stupidity is not similarly handicapped."
Big Bronze Rim is offline   Reply With Quote
Old 03-14-2008, 01:21 PM   #9
shmiddy
shmiddy's Avatar
any one feel like posting up pics of what you guys are talking about? maybe 240trainee's fuel set up and big bronze's grinding???
pos reped for u help
greatly appreciated
i fully de-volved
Old 03-14-2008, 04:07 PM   #10
sac
sac's Avatar
sac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymore
haha.. i was going to do this. But then decided i am either going to build my own manifold, or buy greddy.
sac is offline   Reply With Quote
Old 03-14-2008, 08:55 PM   #11
Big Bronze Rim
Sorry, I didn't take pictures of what I cleaned up. Just picture lots of roughness in the ports and the "seams" of the casting in the runners are rough and need to be smoothed out.
Old 03-14-2008, 09:41 PM   #12
efrain240sx
efrain240sx's Avatar
efrain240sx will become famous soon enoughefrain240sx will become famous soon enoughefrain240sx will become famous soon enoughefrain240sx will become famous soon enough
I got mine of some kid who crashed his car, got it for only $30 . But like the guys said it needs to be grinned down allot because the casting sucks. Ooh and mine don't leak either.
efrain240sx is offline   Reply With Quote
Old 03-31-2008, 12:25 AM   #13
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
do greddy intercooler cold pipes for greddy intake manifolds work with the freddy?
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 03-31-2008, 12:29 AM   #14
Jordan-S13-Silvia
Jordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the rough
yes they work perfect but their is an alternitive to the greddy cold pipe for 3 to 4 times less than a greddy coldpipe.
just look in this link only $25
and you musat use a S14 Throttle body pully 26$ from frsport.com.
http://www.courtesyparts.com/Merchan...Code=320-1104C
Jordan-S13-Silvia is offline   Reply With Quote
Old 03-31-2008, 01:38 AM   #15
ichibans13
ichibans13's Avatar
ichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enough
i have heard of the freddy's cracking at the seams, or leaking. sometimes things dont line up right, because they're mass produced as cheap as possible. but i did have a friend that never had any problems with his. guess its just the luck of the draw.
|OO\____/OO| Okinawa JP 2003-2006
Currently: R14 -- Carolina Nissans Elite
ichibans13 is offline   Reply With Quote
Old 03-31-2008, 08:30 AM   #16
Big Bronze Rim
Yup, that is the cold pipe you need. However, you don't HAVE to use the s14 TB pulley. You can make a cable bracket to locate your cable which will allow you to use the stock s13 sr pulley.
Old 04-07-2008, 12:58 PM   #17
shmiddy
shmiddy's Avatar
^^^ thats gold. i got a top mount turbo set up do inna have to make my own hot pipe
i fully de-volved
Old 04-07-2008, 01:07 PM   #18
s14_legend
s14_legend's Avatar
s14_legend is close to perfections14_legend is close to perfections14_legend is close to perfections14_legend is close to perfections14_legend is close to perfections14_legend is close to perfections14_legend is close to perfections14_legend is close to perfections14_legend is close to perfections14_legend is close to perfections14_legend is close to perfection
i would just save up & wait to buy the greddy one...your gonna end up paying for it later if something goes wrong...ebay stuff is always ebay stuff...ive seen them crack it aint pretty
s14_legend is offline   Reply With Quote
Old 04-07-2008, 03:47 PM   #19
Big Bronze Rim
Are you talking about intake manifolds? It is documented that many tubular exhaust manifolds purchased off of ebay have cracked (quality manifold crack too though), I have yet to see an intake manifold actually crack. I have heard stories that the castings were so porous they would leak, but never crack. Not saying it hasn't happened, it's just the first time I hear of it. If you are willing to do the work that is required to make the Freddy manifolds useable, they are an ok deal. However, it is still quite apparent that if you want the highest quality, buy the real deal.
Old 04-09-2008, 04:12 PM   #20
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
just send me your manifold and not waste your time on something that will be useless...check the fabrication thread, towards the bottom of the page...just waiting on the cast centerline plenum but you have a choice to run a front mounted throttle body too
or be cool and go centerline.
also we can do a q45 or what ever TB you want.
TougeLabs is offline   Reply With Quote
Old 04-09-2008, 05:20 PM   #21
Bobafreak
Bobafreak's Avatar
Bobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfectionBobafreak is close to perfection
Good cost for a freddy but if you dont know what your doing and want direct bolt on get a greddy. I think that sums it up.
*VIOLENT RUNNING TRIBE*
"Love is god, hatin is satin!"
Bobafreak is offline   Reply With Quote
Old 04-10-2008, 12:12 PM   #22
jsasrsr
jsasrsr's Avatar
jsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of light
Send a message via AIM to jsasrsr
If your willing to put alot of work into it, then yes, there pretty decent. But they come with all sorts of trouble when you get them. There rough, uneven, pitted, and burred all over the place. They usually are a nightmare to bolt up, and you have to fab up somthing to mount the TB on or weld it...
Your best bet would be to call up jspec.com and get them to order you a JDM intake mani for around $2-300 or so. I did that, welded on a 90mm wilson's ford mustang TB, Pc'd it and I get more airflow than any one person could use!
jsasrsr is offline   Reply With Quote
Old 04-10-2008, 12:24 PM   #23
240trainee
240trainee's Avatar
I actually bought one and it bolted right up and is fine, I need to pull it off and smooth it out a lot, when I get a Q45 throttle body I'll clean it up and make it better.
doesn't seem to be bad at all though, but the quality control is horrible, some work some don't. Mine looks like shit, but works.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 04-10-2008, 12:32 PM   #24
Thursday
Thursday's Avatar
Thursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfectionThursday is close to perfection
Send a message via AIM to Thursday
i ran one, had some vacuum issues but other then that and the casting it was pretty much the same
Thursday is offline   Reply With Quote
Old 04-10-2008, 12:35 PM   #25
advin builtsr20
advin builtsr20 is making a name for him/her selfadvin builtsr20 is making a name for him/her self
my buddy is running an ebay intake manifold on his sr and has no problems whatsoever. He's pushing out 360whp and does not go lightly on his car AT all. He's had it on there for at least a couple years. No problems yet.
advin builtsr20 is offline   Reply With Quote
Old 04-10-2008, 12:36 PM   #26
shmiddy
shmiddy's Avatar
the only real thing that im worried about is the fuel injectors and rail bolting up properly.................................
i fully de-volved
Old 04-10-2008, 12:49 PM   #27
advin builtsr20
my buddy has 550's on his that he up-graded too and had no problems with install of them. I'm not sure what company on ebay he bought his from cause so there's so many damn places on there selling the knock off of the manifold. anyways man, best of luck to you. Just remember, you can never go wrong with a real greddy...just broke for a little bit! But definitely not disappointed!
Old 04-11-2008, 12:42 PM   #28
shmiddy
shmiddy's Avatar
^^^ thanx
bump for more injector/fuel rail info
i fully de-volved
Old 04-11-2008, 03:00 PM   #29
Tearlessj
Tearlessj's Avatar
I know someone thats making 450whp on a Topspeed manifold.
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 04-11-2008, 05:04 PM   #30
Def
I had the exact same experience with mine. Just a lot of sanding/grinding and test fitting things. Fuel rail bolted up fine.
Took me more than a hour to do all the grinding/sanding, but I was pretty anal about it and reshaped the TB port - which I think was shaped off the GReddy casting, but it sucked from a flow standpoint(lots of separation right past the TB). I also did an 80 grit finish all the way up the ports and at least a 1" radius into the plenum, and retapped all the holes(they were a little janky, and lots of chips in there).
I also had to grind a few of the manifold to head bolt holes to get them to line up, looks like they drifted on about half of mine. Not an issue, except it just took some time.
Overall, I'd still buy it over spending the $$$ for the real GReddy, which just seems very expensive given the size of the casting and the flow path just past the TB(if it's the same on the GReddy vs. FReddy).
