Old 04-12-2008, 04:13 PM   #1
Reezer
Reezer is an unknown quantity at this point
Need advice on how to remove hicas ball joints
Ok, these damn hicas steering ball joints are driving me nuts. I've been trying off and on for a week to get them out with no success. It's pissing me off because it is the last thing I need to do to get my car to pass safety. I have tried banging on them, using a ball joint remover tool, using penetrating oil and heating around them with a propane torch(which I don't think gets hot enought to do anything). The ball joint is supposed to push out from the spindle and the new one pushes in and is held with a snap ring on the back. Any advise or help with how to get these god forsaken things out would be hugely appreciated. The only other thing I can think of to do is to remove the whole spindle and then bang on them with a 5lb sledge till they come out. I really don't wanna do that though if possible cause then I have to deal with trying to get a whole bunch more rusty bolts free.
This is what needs to go in. snap ring is already attached to the back.
This is where it needs to go. I already have removed the back snap ring.
Reezer is offline   Reply With Quote
Old 04-12-2008, 04:37 PM   #2
Signum Temporis
Signum Temporis is a well-known jackass
Send a message via AIM to Signum Temporis
*EDIT*
take the spindle off, drill through the center, then try pulling it or hammering it out
Signum Temporis is offline   Reply With Quote
Old 04-12-2008, 08:21 PM   #3
Firestorm
Firestorm's Avatar
Firestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond repute
Send a message via ICQ to Firestorm
take the spindle off, put it in a vice and get some kind of socket (better use a cheap one!) that fits over the balljoint and bash the shit out of it...thats what i would do...maybe heat it up a little, might help...
Firestorm is offline   Reply With Quote
Old 04-12-2008, 08:42 PM   #4
burnsauto
burnsauto's Avatar
use an acetylene torch. you may just want to take it to a shop and have them do it if you can't get ahold of one. should take around 30 minutes for each side.
Old 04-13-2008, 02:33 PM   #5
projectRDM
projectRDM's Avatar
Agreed, remove the upright. Then you can use a cutoff wheel and cut the stud off flush because hammering it like it will just twist the stud around. After it's cut you can get a good center punch on it and beat it or fit it into a press. I've done that before on front ball joints when they're so loose they just flop around.
FORMERLY R240NA
Old 07-28-2010, 04:05 PM   #6
edmorl
edmorl's Avatar
Trader Rating: (24)
edmorl is an unknown quantity at this point
Feedback Score: 24 reviews
sorry for the bump, it's better then making a new thread. But does anyone know the part number for the ball joint on the hicas toe arm ? I can't seem to find it.
edit: found it if anybody else needs this for reference.
edmorl is offline   Reply With Quote
Old 04-02-2012, 07:30 AM   #7
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
It look like the ball joint have frozen in there. Don't bother using a c clamp to press then out because it much harder.. Take the arm out and have it press with 50 ton shop press... It will come out easily and have it press back in..
kennedy8383 is offline   Reply With Quote
