Old 04-24-2008, 04:48 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
FWD sr20de throttle body on rwd sr20det
well i had asked this on here, and couldnt get a definate answer.
my goal was to have a PLUG AND PLAY throttle body swap on my s14 sr.
why you ask? i wanted to retain cruise control.
i tryed ka throttle body. tps is totally different, butterfly hits manifold, and the throttle cables are pulled at a VERy awkward angle. i hear it works on s13 sr though. (high port vs low port, ya know?)
finding a rwd s14 sr20de tb is VERY hard, let alone one with cruise. (i have yet to confirm it was even offered, but i would think it was)
so it dawned on me. 1994-1996 INFINITY G20 & 95-97 200SX are sr20de. i took a look and the Tps matched. so i picked one up today and tried it.
what do you know, perfect fit. cinderella found the shoe that fit, lol.
also it is a larger inner diameter for those of you that want that throttle response too!
i thought this may be helpful in faq, revised of course.
-devon
p.s. i know its a well known fact that rwd sr20de tb works. this is proving that fwd sr20de tb works, and has the extra rotor to allow cruise to be used.
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 04-24-2008, 05:02 PM   #2
S14DB
AFC #1
S14DB's Avatar
Get pics!
Let me know when you figure out the bracket.
Old 04-24-2008, 06:46 PM   #3
boyou2
boyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura about
hey devon,look at this little How To:
http://www.zeroyon.com/index/content/view/23/47/
boyou2 is offline   Reply With Quote
Old 04-24-2008, 06:58 PM   #4
devonkyle77
nice attempt to bring me down.
unfortunately, you fail.
as i stated, i knew of this swap.
the whole point of my swap was to retain cruise control. do you see cruise control on that throttle body?
i see you are living in france. i am french, and even I hate the french.
Old 04-24-2008, 07:04 PM   #5
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
haha... good info for u s14 sr guys. knowledgeable people dont help no1 unless shared.
s13drob is offline   Reply With Quote
Old 04-25-2008, 06:38 AM   #6
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
nice find. Take some pics when you get it all set up.
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 04-25-2008, 07:38 AM   #7
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Subscribed, this sounds pretty great
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 04-25-2008, 07:42 AM   #8
devonkyle77
i am doing a cut/weld of sr and ka brackets.
basically, the base of the sr bracket, and the front of the ka bracket. very hard to put the into words. i will show you when i figure it out guys!
Old 05-17-2008, 02:51 PM   #9
devonkyle77
update! the bracket has been configured! here are the pics. it fits great, i just need to smooth it up a bit more and have it powercoated!
Old 05-17-2008, 03:01 PM   #10
surge s14
surge s14's Avatar
surge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymore
will this fwd sr20de TB fit on a s13 sr20?
how much bigger is it bigger then s14 sr20?
very nice work on the bracket work sir hope it turns out well.
surge s14 is offline   Reply With Quote
Old 05-17-2008, 03:32 PM   #11
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
S13 guys don't need to upgrade the TB since they all come standard with a 60mm TB. S14 sr20det guys have a 50mm tb hence the upgrade. Only the s14/s15 sr20de (n/a) motors came with the 60mm tb. Good find, and great work.
eek is offline   Reply With Quote
Old 05-18-2008, 10:36 AM   #12
devonkyle77
i think this thread is faq worthy if you edit some posts out mods...
Old 05-18-2008, 11:03 AM   #13
S14DB
AFC #1
S14DB's Avatar
I still see no installed pics. :P
Old 05-18-2008, 11:04 AM   #14
devonkyle77
as soon as this monsoon in the midatlantic finishes i will get some, lol.
you are hard to please, i may add.
Old 06-04-2014, 09:59 AM   #15
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Yes, old thread. BUT this thread keeps turning up in my searches for installing cruise control in my S14 SR. Figure I can provide a small update. My apologies if this is already common knowledge.
The P11 (99-02) G20 throttle body bolts up, and the throttle position sensor can be swapped over without an modifications. The S14 TPS wiring also plugs into the top connector if you don't want to switch sensors around. The bottom one is for auto trans WOT/Closed switches, leave unplugged.
Here are some pics of a 99 G20 throttle body and my S14 SR20DET throttle body:
P11 left, S14 Right.
S14 left, P11 right. Essentially identical.
P11 left, S14 right. TPS sensors. Use top plug on P11 for a true PnP affair.
Cleaned up P11 TB with S14 TPS installed. Need to fabricate a cable bracket since nothing really lines up anymore. Too bad the OPs pics don't work.
Installed. On S14 the left coolant line comes strait out, but there's enough hose to connect to P11. It has one vacuum port, the S14 TB has 2, but one is plugged anyway.
Hope this helps future searchers.
Old 06-04-2014, 08:57 PM   #16
ultimateirving
ultimateirving's Avatar
Hey man I was running the same p11 tb on my redtop for a few months but then I noticed the throttle body seals leaking under boost. I swapped back to a different stock s13 sr tb and it's never been an issue since.
I have 2 theories either the p11 have different seals that don't hold boost as well or being that I live in Arizona I feel the seals could
Also be old and dried out. Especially since I got my throttle body from a junkyard out here who knows how long it was exposed to the az heat.
Z32 with lq4 swap
Old 06-05-2014, 08:17 AM   #17
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Thanks for the heads up. Something I will pay attention to when I get this installed.
Old 06-05-2014, 11:38 AM   #18
ultimateirving
For sure. I was chasing that leak forever. And honestly I feel it's more likey crusty dried out seals than anything but just figured id offer it up.
Z32 with lq4 swap
Old 06-08-2014, 03:42 PM   #19
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
Ive been running a G20 throttle body on my notchtop for a while now. It's good to note that on top of having the extra pulley for cruise control, it's also 10mm larger.
Hoffman5982 is offline   Reply With Quote
