#33 |
lol.. not the quickest way.. but i dont see why you couldnt stuff that under your aero. haha
[ame]http://www.youtube.com/watch?v=lOmAe-WKQmo[/ame]
rip bobby.. you will be missed.. Last edited by d r i f t swift; 04-24-2008 at 09:54 PM.. Reason: fixed link |
#35 |
rip bobby.. you will be missed.. |
#36 | |
![]() Join Date: Feb 2005
#37 |
![]() Join Date: Sep 2005
Wood nailed together in a "step-up" style. I also have a Harbor Frieght low profile jack that works just fine to get under my lip and jack on the tow-hooks(not my first choice. No issues yet. Even on a damaged one)
#38 |
![]() Join Date: Nov 2004
thats weird i just find it easier and quicker to just snip 3 zip ties from sideskirt near rear wheel on driver side and slide squirt out so jack clears, then just slide low pro jack and jack up from rear subframe bolt. from there i can get both rear tires off the ground quick then i could by having to get out of car and set up blocks, get back in drive and drive on black, get out of car and tray to get jack under diff.
#39 |
![]() Join Date: Feb 2003
+1 for the stock jack ... stock jack a little and then 4 ton jack up the rest ... how does that pneumatic jack thing work? where does it go?
#41 | |
#42 |
i think the best way is to use ramps
then jack them at the towhooks. thats what i did. i couldnt get my super low jack under my frame rails and i didnt even have a kit. GL |
#43 |
![]() Join Date: Jan 2006
i use a scissor jack/stock jack.
slide between wheel and side skirt and slip it behind the side skirt to the pinch weld or sub frame bolt. whatever. takes like 2-3 minutes to change a wheel if you have coilovers, even in the rear. |
#44 | |
wooden ramps and wood shop ftw hahaha |
#45 |
![]() Join Date: Jan 2004
I currently don't have aero, but I've used combinations of wood planks, ramps, and tow hooks.
I don't see why anyone wouldnt have at least a plank of wood with them at an event.. just pick up shit on the side of the road.. lol i've found various sizes of lumber for use...
D-Street.net | bcuison.wordpress.com |
#47 |
Yeah I bought 3 pieces of 1x6 wood planks from Home Depot, got home, sawed 1 of them in half, then nailed each half to 1 of the full planks.
Raises the car 2 inches and don't have to take the front bumper off. I might have to add a few more to it, so it acts like a total ramp system for the front and rear of the car, for those annoying days like maintenance day where you have to crawl under the car to change tranny or diff fluids. In that case, all you'd have to do is make the ramp long enough so that after the front wheels go up the ramp, it will level off a little bit before the rear gets on, so when the rear gets on, you can have the car go up another few inches, that way you can get a jack underneath the front and the rear easily. Plus it's something to do... when you're bored. |
#48 | |
![]() Join Date: Apr 2003
get a good jack that doesn't have to move far to go up
get a 2x4 that's like 5" long...cut in half at a 45* angle so you make little ramp things put them behind rear wheels and reverse up them then jack from diff done
![]() Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
#49 |
![]() Join Date: Nov 2007
![]() ![]() ![]() Feedback Score: 27 reviews
Find a stock honda civic jack at a yard and shove it under your car and manually turn it with a small screw driver till its high enough to get a jack under. Now your not carrying wood or anything. Just a small 1" by 12" jack and your main jack. Or build some cheap wood ramps-
#55 |
Get some bigger friends.
Lifting the side of a 2500lb car by its wheel well, enough to slide a jack under it isnt an amazing pheat...... and its free.
What the hell is "BALLER" or "GANGSTER" status, about a 240sx? |
#57 |
#58 | |
none of you drive more than once a month none of you are that consistant none of you have taken that much flex out of an S-chassis |
#59 |
![]() Join Date: Sep 2007
i just slide my jack under the diff and jack it up. since my car has such gay ride height
#60 |
![]() Join Date: Feb 2008
and jacking the car up on the back panel?
![]() anyhow, i just drive backwards onto wooden blocks, clears just enough to get the jack under the diff
