Old 02-20-2003, 12:16 PM   #1
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
Smoke : Valve seal or piston ring
Hi !
3 month ago my car started to burn a lot of oil .. Well
at idle may car is smoking a litlle
After a 3-4 second load at 4000 RPM when i release the throttle there a very big cloud
of smoke coming out my exhaust.
anyway ive got a compression test and the mechanic was telling me it was one off my piston ring... i have read some webpage and its look like more a valve seals problem but i want your opinions just to be sure.
if i take out my valve cover, can i see the valve seal and see if they need repair ?
one more thing .. i opened my oil feed on the valve cover and it was blowing oil everywhere and there was some Puff of smoke coming out at intermitent interval.
well hope you can help me.. if i cannot do nothing im gonna buy an old ka24E. I want to keep my 240sx its a damn nice car...
cya everyone
thx for the help !
Fred
F3600 is offline   Reply With Quote
Old 02-20-2003, 01:53 PM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Does the car smoke when you start it, or accelerate from a stop light, or when you punch it?
If it smokes after sitting, it's probably a valve seal.. if it smokes when you shift or punch it, it's probably a piston ring.
-Jeff
Whatup?
Old 02-20-2003, 02:09 PM   #3
F3600
F3600's Avatar
when i start my car it doesnt smoke .. the smoke start after maybe 30 sec but when my car is at normal temp there a lot more smoke
when im driving i have a long smoke cloud that follow me and when i stop.. theres a burst of smoke coming out almost 2x the size of my car ... pretty chezzy feeling when everybody look at you
(i dont drive my car anymore for that reason)
Fred
Old 02-20-2003, 04:35 PM   #4
AceInHole
Autox Technician
AceInHole's Avatar
What were the #'s from the compression test? If the mech said it was a piston ring from the compression test, then I'm guessing you're numbers were off. If it was a valve seal, your compression numbers would be fine (unless you ALSO had a bad valve seat). In fact, oil leaking into the combustion chamber from a bad valve seal might raise your compression test numbers. IMO it's something below the head (assuming the compression test showed a failing number on it) like a headgasket or piston ring.
Old 02-20-2003, 06:47 PM   #5
F3600
F3600's Avatar
There were one cylinder i think were very low (it was 3-4 month ago i dont remember...) well im guessing an engine swap would be more simple . after the swap im gonna tear apart the old one to actually check what wrong with it and learn :P
Thx for you help
