Old 05-01-2008, 11:54 AM   #1
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Redtop help
Sooo, I just got done swapping in a new T25, changing injector O-rings, and setting timing according to frsport.
When I start it and let it warm up, it idles at 2000 and I get this white smoke coming from my exhaust manifold and out the exhaust.
Just like this...
[ame]http://www.youtube.com/watch?v=m9ar8c9zi8o[/ame]
With the idle, I think its my coolant temp sensor. I used the one from the KA.
About the smoke... what do you guys think it could be?
flip3d is offline   Reply With Quote
Old 05-01-2008, 11:58 AM   #2
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection
Send a message via AIM to 1QUICK4 Send a message via MSN to 1QUICK4
If your old turbo was blown it could be oil still from it, or any oil leak from taking the old one off and putting the new one onthat dripped and is burning off. did you use oem gaskets?
1QUICK4 is offline   Reply With Quote
Old 05-01-2008, 12:15 PM   #3
Sileighty_85
Sileighty_85's Avatar
Wrong Sensor you need the CTS from a 94 Sentra SE-R with the SR20DE
Im at work so I cant see the vid, that all the help i can give ya for now
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-01-2008, 12:36 PM   #4
flip3d
flip3d's Avatar
I reused the gaskets that were on there because they were only a couple weeks old and i dont drive the car because i cant get it running right. the old t25 i had did the same thing. maybe its the copper crush washers but i dont see how it would leak inside the turbo causing white smoke to come from the exhaust.
Old 05-01-2008, 12:42 PM   #5
nicku
nicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enough
well...when I swapped my turbo and changed headgasket....it happened to me. because the surface of the turbo or exhaust manifold had the oil from my hands while I was swapping them. After a day or two, they are burned out....and no more smoke.
nicku is offline   Reply With Quote
Old 05-01-2008, 01:45 PM   #6
just1pepsi
just1pepsi's Avatar
just1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfection
Send a message via MSN to just1pepsi
oil burns blue. water/coolant burns white. too much gas burns black/grey. Hope that helps.
just1pepsi is offline   Reply With Quote
Old 05-01-2008, 03:45 PM   #7
flip3d
flip3d's Avatar
hah. i went to autozone and the coolant temp sensor was the same for 240, sentra, and Z. I went home all wtf so i checked to see if there was any coolant and guess what? Nope. half of it leaked out when i was attaching the coolant lines on the turbo.
thanks for your help guys. Ohhh! is it normal to get surge when just revving it?
I have the HKS SSQ bov. if there is a spring, im not sure how to adjust it.
