Old 05-02-2008, 10:37 AM   #1
jayesone
jayesone's Avatar
jayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the rough
Interior Brake light issue
Hey fellas, This started couple days ago. When I went to fontana speed way. Well the brakes all wow, pads are ok, fuild is ok. But when I drop my e-brake my light does not go off. Is there a sensor somewhere I can Check? Thank for you time.
jayesone is offline   Reply With Quote
Old 05-02-2008, 10:55 AM   #2
g6civcx
g6civcx's Avatar
Low brake fluid. Refill and check for leak or low pad thickness. If nothing else works, check the brake lever switch or for broken wire going to the lever or the master cylinder reservoir.
Old 05-02-2008, 10:59 AM   #3
awesomenick
awesomenick's Avatar
Trader Rating: (33)
awesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfection
Feedback Score: 33 reviews
Fluid is okay? I think there is a sensor under the e-brake cover. Take it off and look.
awesomenick is offline   Reply With Quote
Old 05-02-2008, 11:05 AM   #4
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
maybe the sensor into the BMC is like suuuuper dirty..i cleaned mine and it helped...but def check that fluid.. ^ and like awesomenick said.
lol i cant believe i just said that HAHAH
just like he said there is a little connector deal see if it clipped of or waht not
HS13KLS is offline   Reply With Quote
