Old 05-02-2008, 08:20 PM   #1
2ilvia
2ilvia's Avatar
2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore
new tranny, not spinning or shifting
since the s-chassis section is dead as night ill ask this here too
this is on an s14
just put a 5sp tranny into my auto, i went to spin the driveshaft to put the bolts in the other side and it wouldnt budge, tried shifting it into neutral (without a shifter installed, i tried using all kinds of things to shift it but it doesnt shift) but even if its in gear it should move a little either way, but instead it acts like somethings seized or stuck, motor turned fine when the tranny was unbolted and it ran good with the auto in it, i had the tranny apart and it shifted then but now nothings moving
im guessing trannys bad but like i said i had it apart and it shifted then, only thing wrong with the tranny was the end tip of a shift fork was broken off
edit: just found a socket that fits into the shifter thing where the ball of the shifter goes, put an extension on that, and its definitely not shifting
S14- soon to be powered by 24v cummins- 450lbs tq
2ilvia is offline   Reply With Quote
Old 05-02-2008, 11:33 PM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
did you remove the auto tranny's pilot bushing and put in the manual trans bushing that came with your clutch kit, or did you just force it in there?.....was your ebrake on? hehe
gl man,
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 05-02-2008, 11:39 PM   #3
2ilvia
2ilvia's Avatar
nope, auto pilot out, e brake down...
Old 05-03-2008, 12:00 AM   #4
Z U L8R
Z U L8R's Avatar
could be a bad tranny....if the tranny was fine in another car then it's something you did during installation, that's all it can be man. might have to take it back down to check
gl with it,
Dave
Old 05-03-2008, 12:10 AM   #5
240sxspeed
240sxspeed's Avatar
240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold
selectors
had the samr problemb4 i was swapping ka trans to sr bellhousing and some how on accident while swapping housings i pushed all the slectors down these r located behind th cover the holds the pivot ball 4 the clutch fork also i heard of ruff handling banging dropping them whike not in the car can do this also so buck up take the tranny out and reset and also if u force the trans on with mpacting the bolts it will also do this and your car will pop out of gear 2 lemme me know how u make out
HOME OF THE LOWBALLERS AND INTERNET THUGZ
240sxspeed is offline   Reply With Quote
Old 05-03-2008, 02:24 AM   #6
2ilvia
2ilvia's Avatar
that may be, i might have banged it around too much
Old 05-03-2008, 03:01 PM   #7
2ilvia
2ilvia's Avatar
how do i 'reset' the selectors ? and what do they look like? cant find them in the fsm
Old 05-03-2008, 07:48 PM   #8
ericcastro
ericcastro's Avatar
might be too easy, but is the clutch slave hooked up. u push the clutch in when you try and get it to N ??
Old 05-04-2008, 09:06 PM   #9
2ilvia
2ilvia's Avatar
no its not hooked up but shouldnt it still come out of gear if the car is off?
Old 05-04-2008, 11:24 PM   #10
2ilvia
2ilvia's Avatar
well im guessing these three guys are the selectors
and i just gotta keep from banging the tranny when putting it in, makes sense, shifter was in neutral, tranny was in gear, going in tomorrow
Old 05-08-2008, 09:54 PM   #11
-L(-.O)
-L(-.O)'s Avatar
-L(-.O) is on a distinguished road
okay my question is, is there suppose to be any shaft play up and down? what would cause the pilot bushing to be destroyed even if it was properly lubed(antiseize) and tranny was put in with care not force?...
-L(-.O) is offline   Reply With Quote
