Old 05-02-2008, 08:42 PM   #1
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
Dual electric fans? Burning through thermostats? here's your answer.
so i have tried shitty (hayden) to nice (SPAL) thermostats to control my Dual FAL pushers and all of them burn out (the SPAL lasted all winter though while the haydens worked for a couple of months) so after putting a little thought into it i found out a way to bypass all this bullshit about replacing your =fan controllers, and in the process not spend $200 for a FAL one (mainly cause i would be out a car for a few weeks while it came in)
so i went to the local parts house and found a shitty hayden temp sensor as shown:
after hooking it all up i run the output signal into two relays:
note 30/40A relays
and then i hook up a maxi fuse block (small fuses blocks were melting in 1/2 due to massive heat, i went through about 5 of those things since last fall too):
so basically i am just using the thermostat as an "on" signal for the relays that then pipe the power through 14 gauge wire to the fans and back out to the ground near the fuse box under the hood. i will let you guys know how it holds up, but i figure at worst i will end up replacing relays now instead of e-fan controllers.
anyone else do this? anyone else have problems with e-fan controllers melting down on them?
Tenchuu is offline   Reply With Quote
Old 05-02-2008, 11:30 PM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
yes and yes. all the load is on the relay instead of the contacts in the thermostatic fan control relay/switch. just make sure you use a 30 amp relay (to someone who may be unsure)
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 05-02-2008, 11:42 PM   #3
jhec23
jhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nicejhec23 is just really nice
My setup for my taurus efan is pretty much the same as yours. Try using 10gauge wires though because 14 is a little thin and will get hot everytime.
jhec23 is offline   Reply With Quote
Old 05-02-2008, 11:58 PM   #4
Z U L8R
Z U L8R's Avatar
^ another good point =]
Dave
Old 05-03-2008, 12:24 AM   #5
WWJD
WWJD is an unknown quantity at this point
fan
I'm using a painless them. sensor and swich (relay) using 4 gauge wire. best $60 bucks spent
WWJD is offline   Reply With Quote
Old 05-03-2008, 12:37 AM   #6
250sxdet
250sxdet will become famous soon enough250sxdet will become famous soon enough250sxdet will become famous soon enough
I had the same problem with the fuses melting, so we ended up just hooking the fans up to acc. So basically, the fans are on all the time...it takes a while to warm up, but at least you dont have to worry about the fans giving out.
250sxdet is offline   Reply With Quote
Old 05-03-2008, 12:59 AM   #7
Tenchuu
Tenchuu's Avatar
that will cut down the life of your fans being on all the time.
also-
I was debating going with larger wire but i figured that the relays come with 14 gauge on them, and was unsure if the the large wire would really improve the current flow since the smallest point in the circuit is the relay contacts.
Old 05-03-2008, 02:43 AM   #8
JeremyR
JeremyR's Avatar
JeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the rough
Send a message via AIM to JeremyR
i got the dif fan controller...works great!
JeremyR is offline   Reply With Quote
Old 05-03-2008, 07:49 AM   #9
irax
irax's Avatar
I just had alway used a switch to turn the fans on or off and just waited for the temp gauge to goto almost warm to turn it on.
and wouldn't you want the temp sensor to be on the outlet side of the radiator and not the inlet?
irax is offline   Reply With Quote
Old 05-03-2008, 10:08 AM   #10
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
i run a universal dual fan controller from my local parts store... works fine and it was like $50
aNskY is offline   Reply With Quote
Old 05-03-2008, 11:58 AM   #11
Tenchuu
Tenchuu's Avatar
i just tossed it there so it was easy to get to mainly. and the bottom of the radiator usually runs quite a bit cooler than the top (when i was hitting it with the lazer yesterday) so i figured that i would put it in the fastest heating up part of the radiator, then i lazered the block and made it turn on when the block got to the temp i wanted (got close, then let it idle up till the desired heat was reached. ended up that the block was about 20 deg hotter than the top of the radiator.
and i got PMed about a wiring diagram, i can work one up here in a day or two, it was super easy, but i will do that and post it up.
Old 05-03-2008, 01:23 PM   #12
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
instead of a fuse holder you can also use circuit breaker so if the fuses are popping you don't have to go out and buy more, just flip the switch.
eek is offline   Reply With Quote
Old 05-03-2008, 09:09 PM   #13
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
Whats the temperature at which cooling should begine on these engines? I know that e-fans usually kick on at like 195 degrees F or something in that range. Whats good for the KA?
Pacman is offline   Reply With Quote
Old 05-03-2008, 09:21 PM   #14
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
I have my primary fan kicking on @ 175 F or so. Works great - cooler weather & no traffic = fan doesn't turn on at all.
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 05-03-2008, 10:01 PM   #15
Tenchuu
Tenchuu's Avatar
I'm running a RB25 so i can't help you on the KA.
Old 05-03-2008, 10:56 PM   #16
Z U L8R
Z U L8R's Avatar
Rb25 Ftw!
Dave =]
