Old 05-01-2008, 09:48 PM   #1
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
tps question
what does it mean when my throttle reads 100% and voltage goes up to 4-5 when i unplug my tps? i am running s13 sr with auto harness.
Life is good in the bay.
Eternal_240Sx is offline   Reply With Quote
Old 05-01-2008, 10:36 PM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
a little more information please
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 05-01-2008, 10:43 PM   #3
Eternal_240Sx
when i plug the tps back in, my % throttle goes to 0% and stays there no matter when im flooring the car or otherwise.. i measure the voltage directly from the ecu # 20 pin (throttle position) and it goes from .05 when im not on the throttle to .3 when im stepping all the way down.
car runs like shit i can start it but will die out after letting go of the gas when driving the car. when warmed up the idle will bounce from 800-1100.
Old 05-02-2008, 10:43 PM   #4
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
You have .3 volts at the ECU or the TPS? What are you getting at the TPS as far as voltage readings?
Pacman is offline   Reply With Quote
Old 05-02-2008, 11:19 PM   #5
Z U L8R
Z U L8R's Avatar
black wire should be a constant ground, green/red, or red wire should be 5 volts with the key in the ON position, then white wire should be 0 - 1.0 volt /w throttle closed and with the throttle wide open should be 4.0-5.0 volts. if not, replace with known good tps and continue diagnostics if necessary.
Dave
Old 05-03-2008, 01:50 AM   #6
Eternal_240Sx
thanks guys...will report back
Old 05-03-2008, 01:52 AM   #7
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
Where in norcal are you located?
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 05-03-2008, 09:03 AM   #8
Eternal_240Sx
i am in daly city
Old 05-03-2008, 11:09 AM   #9
downshift_sideways
No Limit Soldier.
Aww shucks..a little far.
I would help you, only if you let me use your multimeter
my shit is stupid wack.
