Old 05-06-2008, 03:24 PM   #1
j0hn-0h
j0hn-0h's Avatar
j0hn-0h is just really nicej0hn-0h is just really nicej0hn-0h is just really nicej0hn-0h is just really nicej0hn-0h is just really nicej0hn-0h is just really nicej0hn-0h is just really nicej0hn-0h is just really nicej0hn-0h is just really nicej0hn-0h is just really nice
Send a message via AIM to j0hn-0h
So I broke the screw on my coil pack
I was tightening my screw on my coil pack and wasn't paying attention and i overtightened it causing the screw to snap. Is there an easy way to take out the imbedded screw and where would I find a replacement?
j0hn-0h is offline   Reply With Quote
Old 05-06-2008, 03:39 PM   #2
used240sxparts
Guest
Posts: n/a
get a tool called an easy out
Old 05-06-2008, 03:41 PM   #3
j0hn-0h
j0hn-0h's Avatar
i was thinking more along the lines of an adhesive since it's not lodged in firmly, just loosely. and would u happen to know where i can get a replacement screw?
Old 05-06-2008, 03:48 PM   #4
rich280zxt
rich280zxt is on a distinguished road
How big is the screw, you could always drill off the head
rich280zxt is offline   Reply With Quote
Old 05-06-2008, 03:50 PM   #5
j0hn-0h
j0hn-0h's Avatar
it's the screw for the coil pack. so, small.
Old 05-06-2008, 04:10 PM   #6
Dousan_PG
Dousan_PG's Avatar
its a regualr 10mm bolt
u can pull one off that holding yoru fender in when u open the hood
its the regular 10mm bolt nissans are covered with
Aaron
Pink GodziRa
Old 05-06-2008, 04:13 PM   #7
PhilthyS13
PhilthyS13's Avatar
PhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfection
It's no big deal. I've got a broken one as well.
It seems pretty common:
http://www.zilvia.net/f/showthread.php?t=162546
PhilthyS13 is offline   Reply With Quote
Old 05-06-2008, 04:54 PM   #8
2fast4y0u
2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore
same here. broke it way in there. just got a standard 10mm bolt to replace it with.
2fast4y0u is offline   Reply With Quote
Old 05-06-2008, 05:37 PM   #9
j0hn-0h
j0hn-0h's Avatar
so it's still safe to drive the car without it screwed down?
Old 05-06-2008, 05:48 PM   #10
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
all the bolts on a s13 break haha..
do what i do go to pick a part grab all the nissan 10's hahha
same with stuff on the long block 10s always brake for cam caps. 10 breaks for the chain tensioner and the threads get gayed up and same with the rear main seal.
do it slow...
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 05-06-2008, 06:07 PM   #11
j0hn-0h
j0hn-0h's Avatar
so can i drive my car safely without the bolt holding down the coil pack?
Old 05-06-2008, 06:32 PM   #12
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
small chisel and hammer.... i did the same thing as long as it aint cross threaded it should come right out... if not you need a regular drill bit and a left handed drill bit.... (aka easy out)
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
Old 05-06-2008, 06:41 PM   #13
j0hn-0h
j0hn-0h's Avatar
so... can i drive safely without the screw holding down the coil pack? i just bought the easy out crap. just waiting on the driving question.
Old 05-06-2008, 06:43 PM   #14
BIZERK
BIZERK's Avatar
BIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud ofBIZERK has much to be proud of
Send a message via AIM to BIZERK
yes, the worst thing that could happen would be that the coil pack wiggles loose and you start missing on the cylinder.
BIZERK is offline   Reply With Quote
Old 05-06-2008, 06:47 PM   #15
cronux
cronux's Avatar
cronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to all
or just dremel a slit in the top, and use a flathead.
cronux is offline   Reply With Quote
Old 05-06-2008, 07:06 PM   #16
j0hn-0h
j0hn-0h's Avatar
okay sweet. the screw is lodged too far into the valve cover to dremel. but i just bought an easy out a few hours ago so all i gotta do is borrow a drill from a friend. thanks guys.
Old 05-07-2008, 08:26 AM   #17
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
This is what was happening with my car when I had a broken coil pack bolt. You want that coil pack bolted down, or at least held in some way (someone in the other thread suggested a quick fix of sticking bottlecaps underneath the coil pack cover to press the packs down). You can drive on 3 cylinders, but you obviously don't want to. My car would usually run fine, but would periodically start BLATting like a WRX and lose power.
It's easy to drill out, took me ~10 minutes.
Also, 10mm? My coil packs are all held in by 6mm allen screws...
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 05-07-2008, 08:31 AM   #18
Sil-Eighty SE-K
bottle caps... lol..... thats a good idea LOL
Old 05-07-2008, 09:09 AM   #19
jspaeth
jspaeth's Avatar
Huh?
That's weird. I know the valve cover bolts are allen screws.........
Daily driven
Old 05-07-2008, 09:17 AM   #20
SHIFT_*grind*
I'm pretty certain I have 6mm allen screws holding my coil packs in...
Shit, now I'm doubting myself.
Allen screws for valve cover bolts? Do you mean coil pack cover?
Old 05-07-2008, 09:47 AM   #21
jspaeth
jspaeth's Avatar
Haha yes I meant coil pack cover.
God I am retarded
Daily driven
Old 05-07-2008, 09:54 AM   #22
SHIFT_*grind*
Nah it's just too many goddamn covers to keep track of
Old 05-07-2008, 11:49 AM   #23
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
EXACTLY. I broke one of these weaksauce little bolts last year. Just removed it with a little flat blade screwdriver and a mallet. Then proceeded to drive all summer without a new bolt.
JVD is offline   Reply With Quote
Old 05-07-2008, 12:15 PM   #24
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
my engine came with a pre broken bolt
i have never fixed it
its been more than three years
wow im lazy, i even had auto classes at the college with every size easy out at my disposal and still nothing.
my point is, yes you can drive it
and the thread pitch is 6mm x 1.00
Need automotive work done in the antelope valley?
Ask me how i can help.
tt99ol is offline   Reply With Quote
Old 05-07-2008, 12:44 PM   #25
deadpirate
deadpirate's Avatar
deadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfection
Send a message via AIM to deadpirate Send a message via Yahoo to deadpirate
the best thing I found to get out is left hand drill bits one of the best $10 spent
On Track Motorsport Supply-saftey stuff call TOM @ (805)484-3435
deadpirate is offline   Reply With Quote
