Old 04-16-2008, 09:02 PM   #1
mandle
mandle is an unknown quantity at this point
Send a message via AIM to mandle
s13 s13 gauge cluster not working
ok here is the thing i pulled my gauge cluster out the other day to replace the plastic cover when i put everything back together and started the car the tach does not work the gas gauge went above full and the coolant temp does not read. all of this stuff was working before i pulled it out. i did notice that when i put the headlights on the gauge cluster flashes on and off. i checked all the fuses and all relays i think. i also put another gauge cluster in the car and it still does the same thing. i have even tried pulling the connectors out of the gauge cluster part way to see if that helped but it didnt. i really need someone to tell me what to check next
thanks
mandle is offline   Reply With Quote
Old 04-16-2008, 09:21 PM   #2
djcslice
djcslice is making his/her stupidity well-knowndjcslice is making his/her stupidity well-knowndjcslice is making his/her stupidity well-known
did you take the battery out of the car before you pulled the cluster? You may have tripped the ECU. I dont have much experience with these cars, I am just throwing out the idea.
djcslice is offline   Reply With Quote
Old 04-16-2008, 09:50 PM   #3
mandle
no i didnt because i have a safc wired in and i didnt want to reset it.
Old 04-16-2008, 10:09 PM   #4
djcslice
that might be it, take it to autozone, have em run a diagnostic check.
Old 04-16-2008, 10:14 PM   #5
mandle
the car does not have a diagnostic port is a 1990 s13 hatch with a sr swap
Old 04-16-2008, 10:19 PM   #6
mandle
anyone else?
Old 04-16-2008, 10:28 PM   #7
MADE
MADE's Avatar
MADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant future
If it worked before I'd pull it back over and recheck everything. I know you said you did already but you might have missed something.
MADE is offline   Reply With Quote
Old 04-16-2008, 10:47 PM   #8
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Recheck wiring. Check grounds. Check fuses. Check all connections and relays.
HalveBlue is offline   Reply With Quote
Old 04-16-2008, 11:05 PM   #9
mandle
i checked all fuses in the car and i checked under the hood too is there anywhere else i should check for relays or fuses?
Old 04-16-2008, 11:11 PM   #10
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
this would be stupid
but my brother did it
you did'nt plug the cluster in backwards did you?
sblack13 is offline   Reply With Quote
Old 04-16-2008, 11:13 PM   #11
mandle
how can you plug it in backwards the plugs only fit in one way ?
Old 04-16-2008, 11:25 PM   #12
sblack13
sblack13's Avatar
it will plug in backwards if you force it.
Talking about one of the plugs on the back of the cluster.
Old 04-17-2008, 05:19 AM   #13
mandle
no mine went in with no trouble so that cant be it anyone else got an idea
also if i disconnect the battery will my safc setting go away?
Old 04-17-2008, 05:54 AM   #14
supergoob
supergoob will become famous soon enoughsupergoob will become famous soon enoughsupergoob will become famous soon enoughsupergoob will become famous soon enough
dude i did the exact same thing 2 days ago...took out the cluster and when it went back in, nothing worked, including my AC blower among other things. Mine was a fuse, so i'd check all your 10a and 15a fuses under there WITH A TEST LIGHT! make sure you get continuity on both sides....just cuz the fuse is good doesnt mean you didnt fry a wire....good luck man
supergoob is offline   Reply With Quote
Old 04-17-2008, 04:15 PM   #15
mandle
ok i try putting in new fuses see if that works
anyone else know of somethings i should try
Old 04-18-2008, 05:38 AM   #16
mandle
anyone else have any info to share about my problem?
Old 05-06-2008, 11:35 PM   #17
Exas Spec D
Exas Spec D's Avatar
Exas Spec D is on a distinguished road
Were you able to fix the problem? Cuz I have the same exact problem. It was caused by a short. My driver side tire rubbed the fender well and got through the wiring harness and the wires fused together. I then replaced all the broken fuses, fixed the wiring, and still my cluster wouldn't work... Fuel, Tach and Speedo gauges won't work. What to do...
Exas Spec D is offline   Reply With Quote
Old 05-07-2008, 02:16 AM   #18
Exas Spec D
Anyone? I need help to fix my Fuel, Speedo, and Tach gauges. I'll go and take it apart tomorrow and take a look at the Cluster itself.
Old 05-07-2008, 06:30 AM   #19
mandle
your gauge cluster might be fried try another one if that does not work then the dash computer is bad
make sure you check all the fuses and relays and check all the connectors and grounds too
i still have not gotten my fixed yet but i plan on spending all day thursday working on it and if i find a soluation i will post it up
Old 05-07-2008, 07:02 AM   #20
mandle
if anyone else has had this problem and has a soluation post it up plz
Old 02-27-2012, 02:13 PM   #21
S13cl9kid
S13cl9kid's Avatar
S13cl9kid is just really niceS13cl9kid is just really niceS13cl9kid is just really niceS13cl9kid is just really niceS13cl9kid is just really niceS13cl9kid is just really niceS13cl9kid is just really niceS13cl9kid is just really nice
Kind of a old thread bit I have this issue also any help
http://img.photobucket.com/albums/v477/erupt/Luis_sig.jpg
S13cl9kid is offline   Reply With Quote
Old 11-22-2012, 08:07 AM   #22
240SpoochSX
240SpoochSX is an unknown quantity at this point
ya im having the SAME issue, everything stopped working, climate control, pwr windows, flashers, gauge cluster all kapoots
240SpoochSX is offline   Reply With Quote
Old 01-01-2013, 09:42 PM   #23
VinceDude
VinceDude's Avatar
VinceDude is an unknown quantity at this point
Mine was working fine before I went to drift the car and then all the sudden everything died. Lights still work and fuel gauge still works. The rest like the little lights that pop up before ignition don't come on anymore. Idk what it is I checked my ecu wiring, I checked the fuses, and I'm about to pull the dash. I've also already replaced the gauge cluster and it still persists on not working. WTF is this shit.
VinceDude is offline   Reply With Quote
Old 01-02-2013, 07:08 AM   #24
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Did you check your fender wiring harnesses before anything else?
CLICK HERE!!!
Old 01-03-2013, 09:48 AM   #25
VinceDude
VinceDude's Avatar
yeah that was never touched I have it tucked up.
Old 01-10-2013, 12:30 PM   #26
jroy1234
jroy1234's Avatar
jroy1234 is an unknown quantity at this point
do this first.
And also check the 75a alinator fuse and the wiring that is under it.
There was a service bulletin Nissan sent out in '97 on the wires going to the Alt fuse. They tend to oxide easily and break off. not to mention there is a metal clip that ties 2 wires to one side of the fuse. Mine had somewhat of the same problem come to realize the wires had broke off under the fusebox with a clean cut (go figure)
hope this helps
jroy1234 is offline   Reply With Quote
Old 01-10-2013, 11:23 PM   #27
VinceDude
VinceDude's Avatar
Check and recheck your fuses! When mine first went out I did this with a multimeter and they all had continuity. I tried it again the other day for the hell of it and found out the "meter" fuse was blown and as soon as I replaced that my cluster started to work again. Check em with the multimeter and pull em too just to double check everything.
Old 01-10-2013, 11:40 PM   #28
androcathr
androcathr is an unknown quantity at this point
androcathr is offline   Reply With Quote
Old 09-24-2016, 08:23 AM   #29
stevep41
stevep41 is an unknown quantity at this point
Problem Solved
Same problem here with a 1995 240 sx. The issue is the FL100 A breaker that is located under the hood, passengers side, in the fuse box. Once that pops, the headlights will continue to work, but the gauges, power windows, brake, tail, signal and hazard lights, as well as the BEEP when you open the door with key in ignition, all stop working. I put some tin foil in temporarily until I can locate one of these.
stevep41 is offline   Reply With Quote
