Old 02-25-2003, 01:47 PM   #1
rps13kid
rps13kid's Avatar
rps13kid is a well-known jackass
Send a message via AIM to rps13kid Send a message via MSN to rps13kid Send a message via Yahoo to rps13kid
s13 race fuel in a ka
dose it make any difference if you put race fuel in a stock ka24e????
rps13kid is offline   Reply With Quote
Old 02-25-2003, 02:13 PM   #2
d240t2
d240t2 is an unknown quantity at this point
Send a message via AIM to d240t2
Yeah. You'll lose power, but your car will probably be just as fast, because your wallet will be lighter.
Unless you advance the timing, race gas won't give you any power. With advancing the timing, maybe you'll make 5hp over stock for $5 a gallon.
Dennis
d240t2 is offline   Reply With Quote
Old 02-25-2003, 02:15 PM   #3
rps13kid
rps13kid's Avatar
how much do you have to adjust your timing and is it worth it,,i just want to try it because i have a sr20 comming in the next week
Old 02-25-2003, 03:06 PM   #4
d240t2
Well if you are just bored and want to try it...get a couple of gallons of whatever race gas you want to spend the money on. Then advance the timing till you hear it ping and back it off a bit.
I can't tell you how much to advance for a certain type of gas...that is called tuning.
Dennis
Old 02-25-2003, 03:13 PM   #5
TrueSlide
TrueSlide's Avatar
TrueSlide is an unknown quantity at this point
Send a message via AIM to TrueSlide
I wouldnt use race gas unless your engine is pinging or knocking. Other then that your just wasting money.
Real men drive s13s.
#240sx on EFnet
TrueSlide is offline   Reply With Quote
Old 02-26-2003, 11:36 AM   #6
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
maybe race gas is different but when i drop a little octane booster in my fuel in my 81 malibu it feels a little more squirty then if i had no octane booster
And i can tell easily if someone put low octane fuel in my car like 87....
my .02
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 02-26-2003, 11:42 AM   #7
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
well, if he's talking about using race gas with an SR20, he'd just be able to up the boost a bit more "safely", that's all...
AceInHole is offline   Reply With Quote
Old 02-26-2003, 11:49 AM   #8
AKADriver
AKADriver's Avatar
Race gas in a KA24E...
It'll run, poorly. Power will drop significantly, even if you crank up the timing.
Pointless.
Old 02-26-2003, 10:04 PM   #9
Muzzy
Muzzy's Avatar
are u saying its pointless to use race fuel or just pointless in a weak ka24e
lemme have a dollar
Old 02-26-2003, 10:12 PM   #10
AceInHole
Autox Technician
AceInHole's Avatar
It's pointless in a weak ka24e
You'd have a use for it with:
1. extremely high compression ratio
2. high boost
3. minimally with advanced timing
Old 02-27-2003, 06:27 AM   #11
litlespic
litlespic is an unknown quantity at this point
Send a message via AIM to litlespic
The way I have heard it explained is the more octane, the slower burn, and the more heat it can endure until ping's.. so that is why race cars with timing, boost's, nos.. so that they can run MORE or what they do already with out ping.. I have always been told to run the least octane with out pinging.. that will result in the best performance.. but whatever works for you..
88 Merkur, just a little 2.3
litlespic is offline   Reply With Quote
Old 02-27-2003, 09:30 AM   #12
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
one more thing:
C116 is leaded. run that and you'll kill your 02 sensor and your catalytic converter. yay! all that for .5 hp (after adjusting timing)
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 02-27-2003, 01:33 PM   #13
TrueSlide
TrueSlide's Avatar
Thats about right(pretty close), the higher the octane the harder it is to burn, when you have really high compression/boost and then lets say you drop to 87 octane, the gas ignites under pressure/compression causing a "knock" or "ping" The higher the octane the harder it is to ignite.
#240sx on EFnet
Old 02-27-2003, 02:11 PM   #14
SRKperformance
SRKperformance is an unknown quantity at this point
Send a message via AIM to SRKperformance Send a message via Yahoo to SRKperformance
one word.....waste
SRKperformance is offline   Reply With Quote
Old 02-27-2003, 05:14 PM   #15
kerv
kerv is an unknown quantity at this point
Yea, why do that?
Kerv
89 Nissan 240sx FB
Alberta Canada
kerv is offline   Reply With Quote
