1993 240sx: replace arm or just ball joint?
this is the front lower control arm ball joint.
Last edited by surreybc; 05-26-2008 at 01:00 PM.. Reason: confused ball joint and bushing |
![]() Join Date: Feb 2008
its easiest to just replace the arm.
yes it will make a difference in alignment, which is why they sell aftermarket FLCA's w/ball joint that are adjustable. but i perfer the oem flca. IF its not bent i personally would just replace the ball joint itself, not the whole arm.
99rs coupe Currently Collecting parts for STi swap |
![]() Join Date: Dec 2006
Front Lower Ball Joint Installer
![]() TSW Ball Joints 15 bucks each at Autozone
![]() Join Date: Dec 2004
I was gonna replace the whole arm but if it's really only $15 at autozone, I'm just gonna go with that instead. Online they only have $35 duralast ones, let me go check instore though.
it's a RUCKUS life |
go out and buy s14 LCAs.
they are a direct bolt on and are about an inch longer than S13s. gives you more steering angle and more camber. just remember to get an alignment right after because your toe, caster and camber are dramatically changed. -good luck! |
#8 | |
I mixed the price with the Tie Rod ends I got both at the same time m._.m But the lower ball joints are a pain to get out, Intallation is easy if you do it my way ^^ lol you could get the S14's LCA but the ball joints ?cone? /\ is thicker so i dont know how well that would work with the S13 hub assembly
aWingThing.com
![]() Join Date: Mar 2003
Yea, PDM has the whole arm with the joint pressed in for $115. That's the easiest/best route IMO. That's what I did. No dickin around. Just remove old and put in new.
Here you go!
What I do for a living...www.mhrussell.com |
#14 | |
yeah, seriouly go w/ PDM. |
#15 |
![]() Join Date: Dec 2002
We all are, but there's no such thing as a 3 piece ball joint. Bushings can be bought in a 3 piece design though. So are you asking about the ball joint, or the bushing?
#16 | |
thanks. they are local and say i can pick up so no shipping. |
#17 |
#18 |
#20 | |
It took me awhile to understand how to use sockets and a long bolt/washers/nuts to remove bushings ![]()
#21 |
As he tightens the bolt, pressure is directed down to control arm through the sockets so ball joint forced up. not sure what the stand is for accept to prevent control arm from bending where the sockets are pressing down.
some of the youtube videos might be useful [ame]http://www.youtube.com/watch?v=oSadIUnS6Pc[/ame] this is pic of my 93 s13 ball join ![]() this is not my ball joint. ca ![]() these are ball joints for s13 ![]() ![]() Last edited by surreybc; 05-14-2008 at 10:55 PM.. |
#22 |
http://forums.nicoclub.com/zerothread?id=286600&page=1
heres a faq on replacing lower control arm. he gave up using the fork to remove ball joint and used sludge hammer. prolly bad idea especially if you are keeping ball joint and arm. i think the trick is just to keep hammering fork for a long time. i see a lot of people use the jack at front axle. have to find the right spot to lift from. using a fork to release ball joint [ame]http://www.youtube.com/watch?v=8T2ZCEZl20g[/ame] Last edited by surreybc; 05-15-2008 at 06:32 AM.. |
#23 |
![]() Join Date: Jan 2010
![]() ![]() ![]() ![]() Feedback Score: 10 reviews
anyone have the ball joint part number?
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
#24 |
![]() Join Date: May 2019
But a 12 yr old thread to simple google a part...smh u should know better
https://www.nissanpartsdeal.com/oem-...all_joint.html |
