Old 05-14-2008, 09:14 PM   #1
Don Nguyen
Don Nguyen is making his/her stupidity well-knownDon Nguyen is making his/her stupidity well-knownDon Nguyen is making his/her stupidity well-knownDon Nguyen is making his/her stupidity well-known
Send a message via AIM to Don Nguyen
Anodizing rim/wheel bolts?
I want to anodize my Work wheel bolts, the ones that holes the 3 pieces of the wheel together.
Anyone done this before? I figure this might be cheaper than buying a complete set of gold bolts from Work, if that is even possible.
Don Nguyen is offline   Reply With Quote
Old 05-14-2008, 11:05 PM   #2
ayuaddict
ayuaddict's Avatar
if they are aluminum, i'm sure its possible.
Old 05-14-2008, 11:31 PM   #3
SILEIGHTY_DET
SILEIGHTY_DET's Avatar
SILEIGHTY_DET is making a name for him/her selfSILEIGHTY_DET is making a name for him/her self
im pretty sure the bolts work wheels are chrome plated steel . sometimes i will see rust ont the back sides of the bolt and nut .
i wouldnt do it personally , but you could buy gold chrome paint and mask off the wheel instead of taking the bolts out . especially since once you take the bolts out you arent supose to reuse them .
hope this helps
SILEIGHTY_DET is offline   Reply With Quote
Old 05-15-2008, 01:06 AM   #4
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
yes you can. But better. get em chromed or even gold plated.
CoasTek240 is offline   Reply With Quote
Old 05-15-2008, 01:42 AM   #5
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
do alchemy on them to make them gold
Need automotive work done in the antelope valley?
Ask me how i can help.
tt99ol is offline   Reply With Quote
Old 05-15-2008, 01:52 AM   #6
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
Once you take them apart there is a process of getting them back together.
Gaskets, truing the wheel, etc.
Probably more than its worth.
But yes, you could theoretically get them anodized.
whiterps13 is offline   Reply With Quote
Old 05-15-2008, 02:27 AM   #7
an_orange_s2k
an_orange_s2k's Avatar
an_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond repute
hahahhahah. to op im sure u can do this but will it be worth the time/money?
an_orange_s2k is offline   Reply With Quote
Old 05-15-2008, 03:06 AM   #8
skyline34
skyline34 is making a name for him/her selfskyline34 is making a name for him/her self
SR
if there aluminum you could, anadize the bolts, if there steel you can get them plaiting, i got a buddy that works on a plating house.
skyline34 is offline   Reply With Quote
Old 05-15-2008, 03:58 AM   #9
xyooj180sx
xyooj180sx is an unknown quantity at this point
i dowith anodizing at work, but it has to be aluminum i can get most colors.
xyooj180sx is offline   Reply With Quote
Old 05-15-2008, 08:51 AM   #10
Def
The bolts are likely steel. They have been for most 2/3 piece wheels I've come across.
It's pretty easy to anodize stuff yourself, it'll just take forever if you're doing it the ghetto way(battery charger).
Old 05-15-2008, 08:59 AM   #11
e-unit
e-unit is an unknown quantity at this point
Just buy new ones, most multipiece wheels use M7 bolts. You can pick up these up from a place called BFI. Alot of VW guys pick up parts from them when rebuilding their wheels. Here's the link
http://yhst-1918367471896.stores.yah...rsnuandbo.html
e-unit is offline   Reply With Quote
Old 05-15-2008, 09:24 AM   #12
Don Nguyen
I've taken apart and put together multi piece wheels before.
Thanks for the link.
Maybe I should look into plating, to see how much that would cost as well. The only reason I am trying to keep the original wheel bolts is because they say Work on them, but if it is too much work or whatnot, then I'll probably just get the ones you posted in that link.
Old 05-15-2008, 10:06 AM   #13
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Ooooh, nice, might pick some of those up.
Fuck, thats a lot of money though. $1.20 a piece, and I'll use over 100 between the 4 wheels. maybe not. fuck.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 05-15-2008, 11:51 AM   #14
A Spec Products
A Spec Products's Avatar
I would just get your current bolts polished if you are trying to keep it on a budget
New bolts from Work Wheels gets pretty pricey just based on the quantity you'd need (for most of their wheels)
Either that or buy a similar grade bolt/nut from a specialty bolt store, but again that also depends on the design of the wheel
A SPEC PRODUCTS CORP
Old 05-15-2008, 12:22 PM   #15
Don Nguyen
It's a work meister s1 3 piece.
Would the bolts posted above work?
Do you guys have any other suggestions on possible ways to paint my bolts gold? The masking thing and painting them on the wheel may work, but that'd be a lot of work, and prob won't turn out that great.
Old 06-05-2008, 02:50 PM   #16
Don Nguyen
bump, to see if anyone knows those length bolts would work with work meisters.
-Don
Old 06-05-2008, 04:43 PM   #17
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
take one out and take it to a hardware store
like a REAL hardware store. Find the oldest man that works there, he'll probably know exactly what it is on sight. Usually you can get good quality fasteners for an ok price at a good place.
edit: seconding calling/checking Black Forest, they're popular.
high performance driveway photography
zenki s14---v8 fc rx7
my crappy flickr page (drift cars whoo)
Pank is offline   Reply With Quote
Old 06-05-2008, 08:21 PM   #18
Don Nguyen
Called them and no one picked up. I also selected to buy 150 of them, but only 13 was registering each time. They also only offer UPS ground, from what I could tell while trying to check out.
Found a ebay retailer that sells them for about 200 shipped, in bundles of 136 pieces. I am going to see if he can sell me 150.
