Code 45
So the other day I was driving around and decided to have a little fun and drive really quick shifting around 6k well next thing I know a check engine light comes on, so im thinking ok well that is cool I get home and take a look I get code 45, fuel injector leak, I am gonna search right now see if anyone has info on this if I find some ill delete this. But thanks for reading guys.
Your my blessing in disquise, you make me realize, just where I want to be years from now. |
Ok did a search no one said anything about the code 45 but I figured something about it being maybe the O rings leaking? But then why would that throw a code? Anyways I also found some steps to replacing the O rings:
To change seals: 1- Remove STB if u have one 2- Unbolt that round thing from the top of the rail (vacuum lines running into and out of it.) 3- Unbolt rail 4- HOLDING BOTH SIDES of rail, pull STRAIGHT out slowly 5- DON'T DROP THE INJECTORS! 6- Pull out injectors, put in tupperware or something 7- Use some gasoline to remove gunge from injectors w/ rag 8- Clean inside injector boss w/ q-tip & gasoline 9- Check bosses for damage 10- Remove old o-rings and seals 11- Clean o-ring and seal seats 12- lube up injectors w/ vasoline 13- lube up bosses 14- place injectors into manifold 15- CAREFULLY place rail bosses over injector (tails?) 16- Line everything up nice nice 17- GENTLY push assembly together, if u feel resistance add more lube) 18- Rail should now sit right on manifold (bolt should NOT pull assembly together) 19- Wrench bolts back in after lubing them and torque to spec. Anyone know if a leaking O ring would throw a code?
YES, mine did the same ****. i cleand them and reinstalled them same code. i put new o rings on it and it worked fine
240sx s-13 TURBO weekend v-8 killer 90 Talon TSI WARNING.THIS CAR IS EQUIPPED WITH A TURBOCHARGER. DUE TO POSSIBLE BREATHING PROBLEMS UNDER HEAVY ACCELERATION, ALL FEMALES ARE ADVISED TO REMOVE ANY TIGHT FITTING OR RESTRICTIVE CLOTHING FOR SAFETY. |
![]() Join Date: Jun 2001
Yeah, you never want to reuse injector o-rings. Always buy new.
Learn everything you can, while you still have the chance. |
Well I was having a problem with my car shaking a lot after I got stuck in the mud when it was raining here not to long ago and when I went to power wash all the mud off the inside of the wheel I also did an engine wash. Next thing I know i start up my car and no check engine light. Is it a fluke? I guess its a mixed blessing, no more light, but does it still leak?
