![]() Join Date: Jan 2003
6 Speed Tranny?
Would it be possible to run a 6 Speed Transmission on a Ka? I would probably be practical wouldn't it? Lower RPM's = lower gas milage. Maybe off an SR20DET from an S15. Could it work?
Not worth it, the six speed is relatively weak compared to all the other trans. Also, the speed sensor is on the trans I think, nebody correct me please if I'm wrong, so it wouldn't work.
Your car has 4 more liters, and it's unfair to race because I have a turbo huh? |
Speed sensor is on the rear end of the trannie... needed to clarify, and also, I think I remember something about the driveshaft not being the same length.
![]() Join Date: Mar 2003
speed sensor is on the differential for the S15. i'll have to take a look to be sure,but i don't think there are any sensors at all on the s15 6-speed.also the driveshaft is shorter.
Main thing to keep in mind is your shift points. The s15 SR tranny is a six speed, with more gears packed between the same first and sixth ratios. IMHO, the KA has a broad enough power band that you would just be wasting time shifting when you don't need to.
Be careful about the "six speed tranny is weak" debate. I haven't yet seen evidence that it's really any weaker than the five speeds (granted, haven't looked :P ), just that it packs more gears into the same range.
Rowsdower saves us and saves all the world! |
Yes, I look like that
![]() Join Date: Mar 2002
Why are there 2 threads on the EXACT same topic right now?
here's the other http://www.zilvia.net/f/showthread.p...threadid=23899 Last edited by Phlip; 03-01-2003 at 06:41 PM.. |
#7 | |
![]() Join Date: May 2002
That's not how the S15 6 speed works. It has six gears in roughly the same "space" as 5, as misnomer said. the S15's 6th gear ratio (0.767:1) is about the same as the KA's stock 5th gear ratio (0.759:1). So... no improvement whatsoever.
What you want is a double-overdrive 6 speed like the one in the 4th gen Camaro. But, neither of them will fit on a KA anyway. |
#9 | |
#10 | |
