![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Car seems to be down on power, where to start looking?
I have new plugs (NGK Vpower), wires, injectors (stock 270cc), fuel filter, exhaust and hi flow cat, header, did the 248/232 cam swap (248 is +2.5 adv), injen intake.
Car doesn't seem like it wants to launch hard...anything I can look at for the 'tune'. Timing is at 20BTDC. I have a OBDII reader that can check O2 volts, temps, etc. The clutch doesn't seem to be slipping. I am curious to the O2 sensors...my MPG (mostly city about 5 miles back and forth to work) is only 16-18MPG. Here is a data dump. Calculated Load: 24.7% Coolant Temp: 171F Short Term Fuel Trim B1: -5.65% Long Term Fuel Trim B1: 2.3% Manifold Pressure: 9.8 inHg Engine RPM: 1000 (788 without A/C on) Ignition Advance: 20deg Intake Air Temp: 117F Air Flow: 0.7 lb/m O2 B1,S1: 60-800 mV O2 B1,S1(Fuel Trim): -3 to -7 % O2 B1,S2: 680-740 mV O2 B1,S2(Fuel Trim): 99.2% Thanks Å
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. Last edited by alkemyst; 05-22-2008 at 06:31 PM.. |
have the lsd...wasn't looking to keep trying though. A lighter flywheel should always help, but is probably not a solution to a problem.
I am thinking although my clutch isn't slipping that I can see it probably is.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
#4 | |
![]() Join Date: May 2005
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
Doesn't launch hard? Look at motor/tranny mounts. Mine are toast, and it lurches....
![]() Quote:
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
![]() Join Date: Sep 2003
i honestly dont understand if your trying to produce more power or trying to solve a mechanical issue.....
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
![]() Join Date: Jan 2005
your vacuum is at 9.8 inHg at idle?
that cant be right those cams aren't big enough to cause that maybe vacuum leak
Need automotive work done in the antelope valley? Ask me how i can help. |
![]() Join Date: Nov 2007
manifold "vacuum" at idle should be 17-21 inches of mercury. yours says pressure so that would be negative 9.8 right? bad intake valves/vacuum leak? your short term fuel trim is rich that's why your short term fuel trim is -5.% you want those to hover around zero. O2 B1,S2: 680-740 mV i think bank 1 sensor 2 is bad. it should read min voltage of <200mv - >800mv but less than 1 volt. your range is way off thus your ecu is getting a mis calibrated signal and making you run rich.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
Check your ground connections as well. I had a problem with low end big time, it would hesitate like all hell then pull like mad. Turned out the ground connection to the chassis from the negative terminal of the battery was very corroded - a quick check with an ohm-meter showed it had very high resistance.
#10 | ||
Where to you check at ground point and battery neg post? did that 175 on all 4.
![]() Join Date: Jan 2006
seems like its running too rich when you dump it and then clearing out after it starts revving
whats fuel pressure like?
ho ha ho chi chi |
#12 | |
The OBDII shows Manifold Pressure inHg...it's not shown as a negative number. I checked again and some cars show 9.8inHg at idle would be normal. I will recheck and use my brakes to see if this number changes properly. If it is a vacuum leak, where do I start looking?
I can't find the info on how much the brake booster should affect manifold pressure.
Mine was 10.1 inHG today and went up to 11.5ish when I release the brakes and then back down.
