tension rod install.
just put on my new adjustable tension rods. only question is, do i tighten the "bushing" end before or after i lower the car down? i assume after since there is no movement in that end when its tight. if this is the case, how can i be sure where is the right spot for the swivel part to be before i tighten things up?
thanks |
![]() Join Date: Feb 2005
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
I'll help you out.
I noticed when I installed mine that when the wheels are off of the ground the hem joint is even -[]- but when the tires are on the ground the hem joint is slanted -//-. It should be even when the tires are on the ground so there is an even amount of travel within the hem joint for flexing? What I did is just look at the way they were leaning -\\- and then jack up the rear and turn the hem joint the oppisite way -//- then retighten them and lower the car back down and they now are straight -||-!!
#4 | |
