Old 03-01-2003, 11:26 PM   #1
h0m3skill3t
h0m3skill3t is an unknown quantity at this point
sr20 compression test?
i am about to purchase an sr20det but i need to do a compression test on it first. usually, on the ka and other motors, i use a compression gauge with a threaded fitting to go into where the spark plug goes. the problem is that the sr20 comes with the coil packs and im not sure if i can use that threated fitting. does anyone know what type of fitting i need? thanks for the help.
h0m3skill3t is offline   Reply With Quote
Old 03-02-2003, 11:55 AM   #2
JNM240
JNM240 is an unknown quantity at this point
It still has spark plugs. It just doesnt have a distributor, cap or rotor. You can still check compression with the same type fitting as on your KA.
1990 SOHC KA24E Coupe
JNM240 is offline   Reply With Quote
Old 03-02-2003, 02:15 PM   #3
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
What is the compression range suppose to be on a SR?
thnks
autobahNESSA is offline   Reply With Quote
Old 03-03-2003, 12:33 AM   #4
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
150 all the way across is reasonable, 160 all the way across is better , 170-180 all the way across is excellent. you do not want variance from cylinder to cylinder especially if its a 10% difference per cylinder.
New Video
Buy my mounts!
