Intake Air Temp Sensor for Power FC
Does anyone tried or know how to install air temp sensor for L Jetro Power FC?
It seems that if you look at the menus and sensor data the air temp input is available although not connected since the stock SR does not use air temp sensor. I know that on RB26 they have one and supported by the PFC too. The reason I want this is if the functionality is available then air temp is good thing to log (for example to measure intercooler efficiency etc) and perhaps opens up for spark correction due to air temp. |
![]() Join Date: Mar 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
if its anything like the ka24e intake temp sensor, you just need to get creative...
drill a hole in your hotpipe, mount it with a good amount of jb weld (or somethng similar) to keep it air tight...
Goodnight |
![]() Join Date: Mar 2005
This is what I found HERE.
Seems like the function is universally included in all Power FC's, but that doesn't mean you can utilize it with the L-Jetro.
#4 | |
I am pretty sure the IAT dependant functions itself works though, since if you enter the AFR corrections for IAT the car does runs richer/leaner. |
#5 | |
![]() Join Date: Feb 2004
L JEtro does not use an AIT sensor. The input in the sensor check section is there for Djetro versions. you dont need it as it reads through the MAF on your L JEtro model. |
#6 | |
For example RB26 does have IAT sensor while RB25 does not. I have heard before that somebody actually got it to work on RB25 Power FC. |
Unless you actually read the thread or saw the setup, I don't think it's true.
Your best bet is probably just to install a standalone AIT sensor and gauge, separate from the PFC.
![]() Join Date: Dec 2005
If comparitive testing (as opposed to constant monitering) i prefer my multi-meter. Any meter that excepts a thermocouple will usually also record max. min. and avg. values. If quick hook up is an issue simply leave a thermocouple wedged in the inlet side pipe couplers and one on the outlet. you could extend the wires into the cabin and run them off of a toggle switch or record with two meters.
![]() Join Date: Apr 2005
why would you want to connect something completely unneccessary? you dont need an IAT sensor, plain and simple. only MAP ecu's use iat in conjunction with map sensor
#10 | |
I know that you dont need IAT to run L Jetro but I have couple reasons - Power FC has functionality for spark correction based on IAT. As you know the tendency to knock is increased with higher IAT. For example on RB26 stock map, at IAT 60 degrees you start to pull 3 degrees and up to 5 degrees for higher temp. - I use FC Datalogit that has good logging capability. It would be interesting to log IAT for example for measuring IC effectiveness etc. Sure I could use extra TCs to the analog input but its worth trying anyway. |
