Old 02-28-2003, 07:08 PM   #31
AceInHole
Autox Technician
AceInHole's Avatar
Originally posted by litlespic
I so wish I had that much money to dump into the engine too.. and like you said, I said he was dreaming when he joined the board and told us what he did.. but 3 of his best freinds have been on the board for years and can talk for him.. so we dont doubt much of what he says anymore...
and if i said i swapped in a Saturn V rocket engine into my car, and some of the veteran guys jokingly played a long, i'd feel sorry for the newbie that believed me.
maybe you've got numbers wrong, or maybe he's running a diesel engine. 100octane would be less than the c116 race fuel I implied he might be using... but even then, 13.1 compression and 25psi = blown engine. It wouldn't matter if he had adumantium alloy pistons or something.
Old 02-28-2003, 07:11 PM   #32
AceInHole
Autox Technician
AceInHole's Avatar
Originally posted by Kreator
ya. The oil paths got clogged with pieces of the other turbo he messed up.
either that or the oil filter clogged to the point that the #4 cylinder's bearing was oil starved. the end result is the same thing that killed boosteds14's engine.
Old 03-01-2003, 09:46 AM   #33
sykikchimp
WOW addicted
sykikchimp's Avatar
lol.. you know we could do the math.. this is all very basic stuff explained in Corky's book.
Old 03-01-2003, 10:14 AM   #34
litlespic
litlespic is an unknown quantity at this point
Send a message via AIM to litlespic
Corky? is this the guy that wrote the books on exhuast and turbos and all the factors??? Right, we dont listen to anything he said, he said all we need is 2.5 exhaust.. and it has been dynoed that 3" exhuast yeilded a couple more hp's... he is a smart man, just dont beleive everything everyone says.. like you guys dont believe me.. like I said in a previous post, the guy has worked on this engine for years, and has finally come up with a combination that works for him.. maybe some of you arnt willing to take the time to trial and error as he did.. which he knows 13.1 compression and 23psi wont work, but he has done othre things to lower the compression when he turns the boost up.. one of the biggest factors is a long duration cam.. which lets what isnt needed squeez out of the valves at the end.. which he says, gives him the most compression and boost possible under any condition...
88 Merkur, just a little 2.3
litlespic is offline   Reply With Quote
Old 03-01-2003, 11:14 AM   #35
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
and why shouldn't we believe corky, who has a very good book written, but should believe your imaginary friend?
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 03-01-2003, 01:57 PM   #36
AceInHole
Autox Technician
AceInHole's Avatar
so then.... why waste more money on the imaginary engine with badly researched mods that work against the engine (i'm going to play along and forget about math, physics, and such for now)??
I mean.... I wish I could swap a 13B engine into my car and get some high duration cams for it. I'd be the man. Then I'd have to run a NOS cooled intercooler so the rings don't fry.
Old 03-01-2003, 02:05 PM   #37
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
this thread is too funny, its stupid.
pointless thread in the "land of make believe"
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline   Reply With Quote
Old 03-01-2003, 02:08 PM   #38
AceInHole
Autox Technician
AceInHole's Avatar
heh... it started with good intentions.... then it got jacked.
Old 03-01-2003, 02:30 PM   #39
litlespic
Ohh, sorry for jacking the thread.. Ill leave if you want me too.. but dont bash on my freind for taking 5 years to make a bad ass engine..
Kreator, why dont you copy and paste just a little bit further.. "he is a smart man, just dont beleive everything everyone says.. like you guys dont believe me"
Old 03-01-2003, 03:39 PM   #40
AceInHole
Autox Technician
AceInHole's Avatar
yeah, take away the mathematical and physical proof and Corky Bell really doesn't make any sense. I suppose if there was some rationale or any sense in what you're saying, we'd probably believe you just like we believe Corky.
But... reducing compression with overlapping cams.... and on a turbo engine?? You do realize the mathematical compression ratio is not changed. The actual compression ratio might be, but at a large loss of any boost built up. So, if what you're saying is indeed true, he's overworking the turbo for no reason. The actual boost in the combustion chamber would be far less than the boost as read in the intake manifold. Driveability would SUFFER (poor flow control at low RPM... and assumably if the overlap is enough to reach the compression stroke, it would be FAR worse than any high duration NA setup), as would response and high end power (you're killing lot of boost).
Well... if it works (as in runs), that's great. But you've at least got to admit the sheer stupidity of it.
Out of curiosity: would you mind explaining how he prevents or safeguards against "misfiring" in the exhaust manifold when he's losing air and fuel into the exhaust stream from his high duration cam?? How often does he have to replace the turbine? Lots of people here have asked about misfiring systems.... so I'm sure they'd like to know.
Old 03-01-2003, 10:32 PM   #41
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Gimme my thread back ^_^;;
you guys can keep rambling about imaginary engines... but id like to know at least some real numbers for the T3.. please?
?RWHP@?Psi
Maeda is offline   Reply With Quote
Old 03-03-2003, 11:07 AM   #42
Maeda
Maeda's Avatar
Ok according to my (probably wildly inaccurate) calculations
based on the map of the 60 trim T3 at turbonetic's website running 10 psi i should expect to see 170 gain in flywheel HP? putting my s14 at a little over 250 at the wheels?
am i going about this all wrong? >_<
Old 03-03-2003, 03:18 PM   #43
Kreator
Kreator's Avatar
Sounds about right if you have a perfect condition engine....
Old 03-03-2003, 03:32 PM   #44
AceInHole
Autox Technician
AceInHole's Avatar
it also assumes that driveline loss doesn't increase, which it will at higher levels of power.
Old 03-03-2003, 06:40 PM   #45
DarkRaptor42
DarkRaptor42 is an unknown quantity at this point
drive line loss increases at higher levels? Why? Is it because its a continually rotating mass? I dont get it, its been along time since I took physics.
04 WRX STi
90 Sil- Camino
R.I.P. AE86 20v MS
R.I.P. KA-T
www.209forums.com
DarkRaptor42 is offline   Reply With Quote
Old 03-03-2003, 07:39 PM   #46
Kreator
Kreator's Avatar
Ummm.... more heat is generated, so more of it is lost since things will be heating up more.
Old 03-03-2003, 08:43 PM   #47
Maeda
Maeda's Avatar
so what kind of loss am i looking at? hard to say?
think i should just use the t3/t04b instead to make my 250 or so rwhp?
sorry still confused...
maeda
Old 03-03-2003, 09:14 PM   #48
Kreator
Kreator's Avatar
don't think in flywheel hp. Just figure out what you want to be making at the rear wheels. I dont' remember the compressor graph differences on 50 vs 60 trim, but from what i remember the 60 will take you farther hp wise with decent efficiency. 250rwhp will be easily handled by t3 60. t3/t4 will take it farther, but at hte cost of spool up. Now you can get rid of lag with a ball bearing, but thats extra $500 probably noone wants to spend.
final note: if 250rwhp is your final goal, t3 60 will be your best bet.
Old 03-04-2003, 03:28 PM   #49
Maeda
Maeda's Avatar
I ended up with an IHI turbo... equiv to a T3/T04E... was nice and cheap? i think... ^_^
