Old 06-01-2008, 07:51 PM   #1
corriganjoshua
corriganjoshua's Avatar
corriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfection
Send a message via MSN to corriganjoshua
Diagnostics Connector
I have a friend I am trying to help and he needs to know where the diag connector is can anyone help me out?
Team Inertia
Cheap,Fast,Reliable you can only have 2.
corriganjoshua is offline   Reply With Quote
Old 06-01-2008, 07:59 PM   #2
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
under the steering wheel directly above where your left shen.
Its white and is in reach while sitting in the driver seat and leaning forward.... but your best bet is to kneel into the car and take a look-see so you will know exactly!!
-Drew
MadScientist is offline   Reply With Quote
Old 06-01-2008, 08:01 PM   #3
corriganjoshua
thanks a lot +repz
Team Inertia
Old 06-01-2008, 08:08 PM   #4
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection
Send a message via AIM to 1QUICK4 Send a message via MSN to 1QUICK4
-Drew
for an s13? cuz i can't find it anywhere
1QUICK4 is offline   Reply With Quote
Old 06-01-2008, 08:09 PM   #5
corriganjoshua
does this exclude the s13?
Team Inertia
Old 06-01-2008, 08:11 PM   #6
Rnz520
Rnz520's Avatar
Rnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud of
Send a message via AIM to Rnz520
Thats only for S14, for the S13 you have to bridge the gap in the plug and count how many times the CEL flashes
*93 240sx:KA-T, FLTA-2s, MR TR, Greddy F&R bars, Greddy gauges, Cusco brace, etc
Rnz520 is offline   Reply With Quote
Old 06-01-2008, 08:13 PM   #7
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
that sucks, I have a consult cable and obviously i can't use it
*scratches head*
Old 06-01-2008, 09:04 PM   #8
projectRDM
projectRDM's Avatar
CONSULT plug is in the fusebox, above the fuses, on ALL Nissan models. OBD plug is beside the hood release cable on 96-98 S14s, below the glovebox, left side on 95s.
FORMERLY R240NA
Old 06-01-2008, 10:11 PM   #9
4bangers
4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices
I have a 95 and my obd plug is on the passenger side under the left side of the glove box. so is this obd1 or obd2? since 95 can have either one right? how do I know which one is it?
1QUCIK4 - can you take a picture of your consult port? I have one too but somehow it cannot plug into the consult port.
4bangers is offline   Reply With Quote
Old 06-02-2008, 12:11 AM   #10
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
My S14 is the same...connector is on passenger side.
Smurf_240SX is offline   Reply With Quote
Old 06-02-2008, 02:53 AM   #11
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
ka24e - there is no diagnostic connector. (only for s13)
obd I ka24de - interior fuse box, grey plug
obd II ka24de---
95does not have obdII diagnostic port. consult port is in the same location as above. looks the same
96+ (some early 96 models do not have obdII connector). consult port is in th same location as above and looks the same. the obdII connector port is under the steering column to the left. white & thick harness connector(female).
WheelsDirty
Old 06-02-2008, 09:27 AM   #12
projectRDM
projectRDM's Avatar
obd II ka24de---
Completely incorrect. I said it above, you missed it. The grey connector you have pictured is the CONSULT port, found on all 91+ Nissans. Has nothing to do with OBD.
ALL S14s have an OBD port, it's the same plug for both OBD-I and OBD-II. 1995 models (OBD-I) the plug is found below the glovebox, by the console. 1996-1998 models (OBD-II), it's beside the hood release. The protocol is different but they all have the plug.
So to cover it gain since no one car read:
1991-1998 240SX = CONSULT port located above fuses in fusebox, grey plug.
1995 240SX (OBD-I) = OBD plug is found below glovebox, beside the center console. White plug, standard protocol for all US built vehicles.
1996-1998 240SX (OBD-II) = Same OBD plug, but found beside hood release handle.
And, SOHC models (1989-1990) do have a diagnostic plug, it's just not a CONSULT type, Nissan used a different protocol from 1985-1990 on their vehicles. It's a black plug, about 12 pin, found hanging under the dash near the fusebox as well.
FORMERLY R240NA
Old 06-02-2008, 09:29 AM   #13
projectRDM
projectRDM's Avatar
Incorrect. ALL 1995 models are OBD-I. If the plug is under the glovebox it's OBD-I. Build date has nothing to do with it. You will also have a carbon canister under the hood beside the airbox if it's OBD-I.
FORMERLY R240NA
Old 09-10-2013, 10:08 PM   #14
Gordo714
Gordo714's Avatar
Gordo714 is an unknown quantity at this point
1993 240sx
my co worker used to work for Nissan he has an adapter that converts the CONSULT port to OBDII
from the OBDII he connects to his laptop which he has Nissan software to read vehicle ECU
earlier this week i tried to connect it but the CONSULT cable on my car was giving no signal or power
need help finding either fuse or pin number
Gordo714 is offline   Reply With Quote
Old 09-10-2013, 10:25 PM   #15
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
im almost positive 95s had a "mid year" switch to obd2 feel free to search if you don't believe this.
-Mike
s14boy is offline   Reply With Quote
Old 09-11-2013, 03:19 AM   #16
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
-Mike
This post was from 2008, good chance he figured it out or has completely forgotten about this thread in the last half decade. Check your dates before replying to something so old.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
