Old 06-01-2008, 11:15 PM   #1
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
is this good?? (pics)
i just took out my diff today because it was broke. and broke it is. but it looks like some of the teeth that had broken might have messed up gear that come from the driveshaft into the diff. its not much at all realy. its like if you were to drop your cell phone from about 1 foot off the ground. thats how scratched up it is. its on the right side. the left side are some of the broken teeth.
and the ring gear has a even smaller one on it. are they still useable or no? i have a new lsd on its way to me. but just the lsd.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 06-01-2008, 11:22 PM   #2
frankist
frankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura about
dont risk it, get a new open for it, theyre plentiful, last thing you want is a broken lsd. =)
frankist is offline   Reply With Quote
Old 06-01-2008, 11:29 PM   #3
!Zar!
!Zar!'s Avatar
That's weird for that to happen.
Just get another open diff.
Shit is damn near dirt cheap.
Except the people who try to capitalize on knowing that some people need that if they are to weld their diff.
Old 06-01-2008, 11:33 PM   #4
whereda40at
well i have a ats/carbonetics diff on the way. i didnt know if that tiny bit of damage would hurt anything. its not jagged or anything like that. its smooth.
it happend right after i turned my boost up from being at 12psi to 20psi. bad idea. thats what i get for making torque
Old 06-01-2008, 11:52 PM   #5
!Zar!
!Zar!'s Avatar
Nice diff.
Clean the diff out and take it to a rear end shop with the ats. Tell them about what happened and have them adjust your backlash.
You will be fine as long as the teeth aren't marred on the ring or pinion gear.
Old 06-01-2008, 11:54 PM   #6
sijia10358
sijia10358's Avatar
sijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfection
WELD THAT SHIT! lol jk
[email protected]
TIRE CENTRAL "DONALD" 626-227-0150
DRIFT SPEED "QUOC" 562-342-9000
sijia10358 is offline   Reply With Quote
Old 06-02-2008, 03:15 AM   #7
whereda40at
i was just out there a little bit ago and i painted the diff cover and then i was messing with the pumpkin and there is more teeth stuck in the tubing part i guess you would say in the diff. one is stuck and wont come out. but i will mess with it more tommarrow and see what i can do.
what is the backlash to adjust???
Old 06-02-2008, 09:56 AM   #8
whereda40at
any others input??
Old 06-02-2008, 10:15 AM   #9
!Zar!
!Zar!'s Avatar
Backlash is the amount of play or, "click" between the ring and pinion gear.
If you have too much then you will break the teeth off.
If you have too little than you accelerate the wear of your ring and pinion.
It's adjusted via shims behind the input gear.
Old 06-02-2008, 11:07 AM   #10
TurboNetic05
TurboNetic05 is an unknown quantity at this point
ya... backlash is also the same thing on like lathes or similar machining tools. When you adjust the knob there will always be some play. Hope that kinda clears it up as well
TurboNetic05 is offline   Reply With Quote
Old 06-02-2008, 11:12 AM   #11
dirtdiggler666
dirtdiggler666's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
throw it in the trash dont waste your money trying to fix it
dirtdiggler666 is offline   Reply With Quote
Old 06-02-2008, 11:24 AM   #12
s13_maJiK
s13_maJiK's Avatar
s13_maJiK is an unknown quantity at this point
a small chip in the final drive will make noise. If your puting a new diff in replace the gears. you will never say i should of kept my old gears. you will also have a piece of mid of having a brand new rear end with now chips or week teeth.
s13_maJiK is offline   Reply With Quote
Old 06-02-2008, 11:51 AM   #13
white92_s13
white92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nice
just get a new ring and pinion.
they are a matched set, ones messed up replace both. they have a wear pattern. best to just get a new setup, dont risk it installing a nice lsd and having a noisy or potentially breakable rear end again
white92_s13 is offline   Reply With Quote
