Old 06-03-2008, 03:33 AM   #1
xelitex
xelitex's Avatar
xelitex is not welcome here anymorexelitex is not welcome here anymorexelitex is not welcome here anymorexelitex is not welcome here anymorexelitex is not welcome here anymorexelitex is not welcome here anymorexelitex is not welcome here anymorexelitex is not welcome here anymorexelitex is not welcome here anymore
nismo coilovers?
anyone have any experience with these nismo suspension systems...
http://www.thenismoshop.com/ikorb.ph...roduct_id=1276
and yes I searched and didnt find anything...just curious its for a 80% track and 20% d.d. car...thanks ^_^
-who, what, now...? KA<3
xelitex is offline   Reply With Quote
Old 06-03-2008, 09:05 AM   #2
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
the nismo ones are more of a spring and strut combo. For that price or a little more you can get real coilovers.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 06-03-2008, 09:33 AM   #3
Zero_X
Zero_X's Avatar
Zero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to behold
what about the nismo G-attack suspension??? has anyone tried or had any experience with those?
THREE AMIGOS!!
Zero_X is offline   Reply With Quote
Old 06-03-2008, 10:17 AM   #4
burnsauto
burnsauto's Avatar
well for the s13 is a spring/strut package. for the s14 its a coilover system.
Old 06-03-2008, 11:20 AM   #5
aznpoopy
aznpoopy's Avatar
if you're looking at nismo coilovers you should be looking at these
http://www.thenismoshop.com/ikorb.ph...roduct_id=1275
bad: single height adjustable only, only fronts have helper springs so you won't be going super low right off the bat, only for s14, relatively expensive depending on what you're looking for ($1500)
good: super ridiculously comfortable when it comes to handling bumps for an 8/6 kg/mm coilover. depending on the bump it sometimes actually feels softer than flex despite the higher spring rate. i assume this means nismo knows its shit when it comes to setting shocks up for the car.
they are quality. friend has dd and drift his set for 1.5 years and they've held up fine. the downside is single height adjustable means he's 4x4'ing it because he doesn't want to droop the spring. if you want to go lower sans droop you could buy helper springs.
this is the "drop" out of the box.
tried to find an action shot for you guys but the only thing i could find was a picture of him spinning out. hope he doesn't mind. XD
hope that helps
Old 06-03-2008, 11:28 AM   #6
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Not too shabby out of the box.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 06-03-2008, 11:29 AM   #7
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
what wheel sizes there?
bigOdom1 is offline   Reply With Quote
Old 06-03-2008, 11:31 AM   #8
aznpoopy
aznpoopy's Avatar
standard 17x9 +15 fn's all around
Old 06-03-2008, 11:59 AM   #9
ayuaddict
ayuaddict's Avatar
i bet those coilovers feel way better then all the other popular brands.
too bad they don't go low.
..."priorities".
