Old 06-05-2008, 06:57 PM   #1
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
1991 240sx: idle drops 100 rpm when heater turned on
this is the interior heater. Turning on the heater obviously lowers the temperature of the engine coolant so i assume there are less demands on systems so ecu lowers the idle?
surreybc is offline   Reply With Quote
Old 06-05-2008, 09:42 PM   #2
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
it's actually the electrical load of the blower motor that drops the rpm. Turning on the headlamps at idle will produce the same effect. It's not really an issue, most late model and many newer cars do this. Just make sure you have a good charging system.
RedtopTech is offline   Reply With Quote
Old 06-05-2008, 09:46 PM   #3
nixad
nixad has made poor choicesnixad has made poor choicesnixad has made poor choicesnixad has made poor choicesnixad has made poor choicesnixad has made poor choices
postlenght
nixad is offline   Reply With Quote
Old 06-05-2008, 09:57 PM   #4
surreybc
ok. i'll have to check the amps for the blower. I never thought of it as placing much demand on electrical system. Also, I thought that the idle is supposed to go up to compensate for increased electrical loads. My lights lower the rpm about 50 rpm.
Im trying to figure out why my idle plummets to around 500 on cold days when I push clutch in. It plummets quite a bit less when the heater fan motor is off. Ill have to try a new iacv.
Old 06-05-2008, 10:34 PM   #5
bbejj123
bbejj123's Avatar
bbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura about
when u push your clutch i believe there are fans for the clutch to help it cool and not overheat which activate when the clutch is engagded but since it is cold already im not sure exactly how its setup
bbejj123 is offline   Reply With Quote
Old 06-05-2008, 11:51 PM   #6
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
heh ^
surrey, more info plz. what is the idle normally? what if you push in the clutch only? what if you turn on your blower only?
what motor, and what car?
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 06-06-2008, 12:20 AM   #7
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
it all depends on the condition of you charging system and alt. mine drops by 100 too when my FAL fans come on.
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 06-06-2008, 12:37 AM   #8
white92_s13
white92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nice
when i turn the heat on, i drop about 100 rpm as well. turn ac on and it kicks up from 800 or so idle to 1100 or so with the ice cold ac blowing
white92_s13 is offline   Reply With Quote
Old 06-06-2008, 12:50 AM   #9
surreybc
Originally Posted by Z U L8R View Post
heh ^
Dave
KA24DE standard 1991 240sx hatch
If I'm just idling with car at standstill, depressing clutch does nothing to idle but turning on blower drops idle the same 100 rpm. Normal idle is around 800 rpm.
The idle just plummets on cloudy days but on sunny days I dont have that problem.
