Guest
Posts: n/a
what bol ons will really improve your sub 3500rpm power?
Guest
Posts: n/a
cat-back exhaust
Guest
Posts: n/a
o0o run a straight pipe no muffler <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=':D'>
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from nismos14 on 2<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>6 pm on Oct. 23, 2001
cat-back exhaust </td></tr></table><span id='postcolor'> I was just told the Apex-i n1 exhaust will make you lose a little low end but gain a lot of top end...is that correct? |
yes it should do that. ur stock piping will actually give u more low-end than a cat-back exhaust b/c they're geared that way, but the top-end will definitely be improved.
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from BlankFlip on 2:48 pm on Oct. 23, 2001
yes it should do that. ur stock piping will actually give u more low-end than a cat-back exhaust b/c they're geared that way, but the top-end will definitely be improved. </td></tr></table><span id='postcolor'> so overall will I have a faster car if I get the N1 exhaust? |
Guest
Posts: n/a
so there's no bolt on's for low end power? what about a header?
yes, overall u'll have more power w/ a cat-back exhaust, u'll definitely notice it in higher rpm's. but sometimes having too big piping for an n/a won't exactly optimize ur performance, u'd be letting out 2 much air or exhaust. if u get an aftermarket intake like injen, u'll be taking in more air, then u'll need to get that air out efficiently, hence the cat-back exhausts. unfortunately most bolt-ons will take away some low-end, but the overall performance will be better, it's not like ur going to lose ALL of that low-end torque u like.
if u mean retarding ur timing by letting the valves stay open a bit longer, that wont help ur low end either, cuz thats for high end when u can let in more fuel. u'll prolly stutter at low end...
and the right headers shud get u better low end, if they cause the air to spin right cuz the faster the exhaust comes out of ur muffler, the better the performance of ur car, so at low end, there is less exhaust, and the smaller opening makes it shoot out faster, but at high end it becoems constricting, although with the proper header, u can make that air spin and it should improve performance in both low and top ends |
