Old 06-10-2008, 03:44 PM   #1
Taj
Taj's Avatar
Taj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymore
Send a message via AIM to Taj
SR start your engines
How to start the car that had been sitting for a while, without damaging anything?
Taj is offline   Reply With Quote
Old 06-10-2008, 03:47 PM   #2
1989rps13
1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute
Send a message via AIM to 1989rps13
all the fluids should had been drained out when your not use the car for a while. Just put new fluids and ur good to go cooling, oil..
1989rps13 is offline   Reply With Quote
Old 06-10-2008, 03:49 PM   #3
Mi Beardo es Loco
Mi Beardo es Loco's Avatar
Location: A place where boob jobs ruined the best thing about being a fat chick.
Mi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfection
turn the crank manually. It really depends how long it's been sitting.
Originally Posted by JVD
I'm a street thug straight outta compton...
Any of you guys watch gay porn?
Mi Beardo es Loco is offline   Reply With Quote
Old 06-10-2008, 03:52 PM   #4
Taj
Taj's Avatar
Its been sitting for the whole winter and the guy who sold it to me didnt drain any fluids. Can that cause any damage?
Old 06-10-2008, 06:14 PM   #5
Taj
Taj's Avatar
anybody else
dont let all those red squares scare you
Old 06-10-2008, 06:30 PM   #6
Mi Beardo es Loco
well, I don't know. Is it a 240 or a 69 camaro? Check fuel lines, check injectors, check spark plugs, stuff like that. There could be some gunk in the motor but if you crank it manually then you can tell if the motor is seized. If it's seized and you try to start it, that's where the problems start.
Old 06-10-2008, 06:31 PM   #7
Taj
Taj's Avatar
thank you
its a 1996 nissan 240sx with a black top
Old 06-10-2008, 07:19 PM   #8
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
might waqnna dump the gas...what is it after 6 months gas isnt the same
but change ur brake oil and coolant fluids...
might also wanna consider some injector cleaner fluid
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 06-10-2008, 07:26 PM   #9
WagDatto
WagDatto's Avatar
WagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfection
Send a message via AIM to WagDatto
Swap the oil, drain the radiator, siphon the gas. Might as well check the spark plugs while you're at it. Chances are you're probably good to go after that. If you ordered an SR from Enjuku or whatever company you chose, just copy the same sequence.
http://garagezoku.blogspot.com
WagDatto is offline   Reply With Quote
Old 06-10-2008, 07:34 PM   #10
Taj
Taj's Avatar
thanks wagdatto
Old 06-10-2008, 11:56 PM   #11
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
dont siphon the gas... thats childs play............... just hook up a hose to the fuel rail and turn the key on the ignition... itll pump it out..... i say start it up... see what happens.... u could replace the oil if u feel like u need to... to start it up....
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-11-2008, 05:15 AM   #12
just1pepsi
just1pepsi's Avatar
just1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfection
Send a message via MSN to just1pepsi
Drain the fuel and put fresh gas and some injector cleaner in the tank. - Gas gets nasty and gunks shit up. Check the oil, trans fluid (if auto), brake fluid, power steering fluid, coolant levels. add as needed. Check the air filter/intake for any critters or obstructions. Clean the battery terminals and charge the battery. Air up the tires. Try to start it, if it runs (which it should if it did before it was parked) drive it a little bit, then change the oil, trans, brake, ps, and coolant (if you want to) at a minimum I'd change the oil.
just1pepsi is offline   Reply With Quote
Old 06-11-2008, 06:02 AM   #13
Sil-Abc
Sil-Abc's Avatar
Sil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfection
Send a message via AIM to Sil-Abc
shouldnt this be ion tech?
IM JON WAYNE ESQ.... bitch
Sil-Abc is offline   Reply With Quote
