Old 06-11-2008, 04:29 PM   #1
vic2186
vic2186 will become famous soon enoughvic2186 will become famous soon enoughvic2186 will become famous soon enough
s14 Tired Of The Bs!!!!!wings Performance!!
well lets put it like this...bring the car into wings performance on nov 11 2007 to get worked on..it had a stock sr with bolt ons and my intentions were to go with a new fmic,turbo,a little upgrades...it turned out to be a fully blown build at wings performance in nyc...i mean everything u can almost think of was done...top to bottom build..so the motor gets built and they take it to the dyno freshly new just assembeld and the shyt blows up..brand new motor gone to pieces..the whole bottom end shot..to speak i still had a balance due of about 5k..so i go to the shop the next day after the motor blow before they told me and i see my car on the lift getting taken APART..they said the motor was making a real loud clank noise..i new it was done but i had to know why..they tell me over the phone the car is going in for a base tune THE PREVIOUS DAY and not put on the dyno..dont know what happened but the car got on the dyno made 188hp and kabooommmmm...there she goes..then they tell me they towed the car back wateva I THINK THEY DROVE THE SHYT BACK WITH IT ALL FUCKED UP....the motor is gone iam not happy they not happy ..they tell me that they gonna rebuild it..my first build had eagle rods..hks cams..bearing blah blah..so they go ahead and put in the parts they want without asking me first..they order scat rods which i dont mind and bc cams stage one.. REUSE THE SAME PISTONS WHICH HAD BURN MARKS ON IT AND THEY SAY ITS GOOD..THEY ORDER ALL CHEAPER STUFF SO THEY WONT PAY WHAT I PAID!!!mind you bc cams are 234 and the hks are 500..i had the crank knife edged micro pokished the whole works..they were aurgin if i should pay or if should the shop pay..so the shop payed for everything and used cheaper stuff so they wont come out of pocket ...i stressed the shyt enough so i dont say nothin..after 18k yes 18 thousand dollars in a matter of three months WORKIN MY ASS OFF the cars is put back together and ready to get dynoed agian..my balance is paid in full..i ge the car to TOWED TO the dyno shop..and for some reason the fans aint kickin in i call the shop to figure it out and they say it should be working..whateva the tuner try everything and tunes the car it made 420 hp at 14 pounds.. running really fucking hot also..the tuner ask why the fans aint comin at all..and wants to make sure so to make sure my car dont overheat or blow up..i dont know what to tell him since i dont work on cars..whatever the car gets tuned the tuner puts his best into it and the cars is fine to my knowledge..the car breaks down in the middlew of the highway comin back from the shop and i open the hood to see my ac belt snap in half and smoke COMING FROM THE RAIDATOR...i checked the heats needle and it over heated..i pull to the side and call numerous people for help..wateva the car turns back on and i drive it back home upset as hell it was a really rainy day and wind also..the heat needle stay put in the middle..i make it home..park the car..wait till morning..the car does not want to turn on..iam upset..call the shop they send someone to look at it..dont know what the problems is ..so the shope pays for the tow truck and get on the car..take the spark plugs out and boom melted..can even see the head of the spark plug..compression on piston were 115 to 120 the max..dont know what it means they say its ok i know they should be at 150+..they put back newer spark plugs and the car turns on ok..they tell me i need newer ignition like split fire to amp the signal but i dont think thats the problem so i go by it..now i see the shop owner checking the timing???hmmmm why????cuz it was never set b4 the car went out to get tuned!!!!!!!!!!!!!!!! the timng was was off becuase i saw him and his coworker adjusting it like crazy..i know this for a fact u change timing u need to retune or shts get hot..im mad already..they change the timing to what i dont know but i ask if the timing change will the tuned get fcked up ..they said it will mess with it a little..and also the fans were never programmed or wateva they were acitvate when i got the car back..what a shop...so they tell me that everything is fine and they change the oil and sparks plugs and drive the car arounfd they say its ok..i go by there word agian and take the car home thinking everything is settled..boom in the middle of driving home the car turns off agian..i call and they says it the sparks plugs fouling i need better igniiton..im mad agian..thinking 18 thousands dollar sshould have a turn key and drive built car rite..WRONG..NOW THE CAR SITS HERE IN MY DRIVEWAY WITH 20K IN THE HOOD UNABLE TO DRIVE..ITS MAKING A WIERD NOISE FROM THE HEAD LIKE A ROCKER ARM IS LOOSE OR A SPRING OR SOMETHING I DONT KNOW..THE CAR WONT STAY ON AGIAN AND I DONT WANT TO DEAL WITH THIS SHYT ANYMORE..YA AS A SHOP SHOULD HAVE YA SHYT TOGETHER AND DONT BULLSHYT SOMEONE AND TELL THEM THE TRUTH..I KNOW MY MOTOR WAS BAD FROM THE FACES THEY MAKE WHEN THEY WERE CHECKING IT...AND THEY SEND ME OFF SO I CAN GET THE BLAME..I SPEND 20 THOUSANDS DOLLARS AND IM NOT EVEN ENJOYING MY CAR...THANK YOU WINGS PERFORMANCE...YOU KNOW WHAT FOR THE AMOUNT OF MONEY I SPEND I SHOULD AT LEAST BE AT THE TOP OF YOUR PRIORITY TO GET MY CAR RUNNING RIGHT..BUT ALL YA WANT IT THE FCKIN MONEY AND DONT CARE ABOUT THE CUSTOMER..IAM SHYT OUT OF LUCK WITH MY CAR AND NOT EVEN ABLE TO USE IT..I WAITED FOUR MONTHS FOR THIS..AND IN 1 WEEK THE CAR DOESNT EVEN WORK!!!GOD DAM IM PISSED...I HAD IT WITH THIS CAR THAT STUPID SHOP EVERYTHING...THERE IS ONLY SOME HONEST PEOPLE THERE AND THEY KNOW WHO THEY I APRRECIATE EVERYTHING THEY DID FOR ME AND KEPT IT REAL..BUT FORREAL IF YA WERE ME YA WOULD BE UPSET ALSO..IMA ABOUT TO BURN THIS CAR DOWN...THANKS FOR TAKING MY MONEY!!!!AND THANKS FOR ALL THE BULLSHYT YA PUT IN MY EAR!!!THE CAR IS FOR SALE I HAD APREVIOUS POST ON HERE..IM LETTING IT GO FOR 10K... I DONT WANT TO DEAL WITH THIS CAR..OR THE SHOP OR NOTHIN COME AND TAKE IT AND I CAN SHOW U RECIEPTS FOR THE CAR AND DYNO SHEETS...AND IF YA WANT MAYB YA CAN CONVICNE WINGS TO FIX IT THATS IF THEY WANT TO..YOU GOT TO SHOW THE MONEY FIRST THEN THEY WILL HELP..
600hp+plus kouki 240sx coomin soon!!!
vic2186 is offline
Old 06-11-2008, 04:36 PM   #2
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
BIGGEST RANT I HAVE EVER SEEN
i picked out one sentence and i think i got the gist
sorry to hear that
slothonaleash is offline
Old 06-11-2008, 04:41 PM   #3
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
that was gay
dont let your mom see that post
she'll ground you for the whole summer
ho ha ho chi chi
koukimonster139 is offline
Old 06-11-2008, 04:42 PM   #4
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Wow...English grammar is your friend, friend.
Besides, this should be in chat.
Sorry, but I couldn't be arsed to actually read all that shit.
HalveBlue is offline
Old 06-11-2008, 04:44 PM   #5
CSil80
Banned from the Marketplace
CSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfection
As mad as you may be, you need to follow at least some basic grammar.
No one on earth is going to try and read all that.
GL with the car though, whatever it is you're doing with it now.
CSil80 is offline
Old 06-11-2008, 05:03 PM   #6
vic2186
Well Sorry But I Was Upset And Just Typing Away
vic2186 is offline
Old 06-11-2008, 05:07 PM   #7
luftrofl
luftrofl's Avatar
luftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant future
Why Do You Capitalize Every Word Like This?
Engrish is funny in Japan. In America, it's for stupid fanboys.
luftrofl is offline
Old 06-11-2008, 05:11 PM   #8
ThatGuy
Admin Asshole
ThatGuy's Avatar
If you had a problem with a business, then use the review section.
Zilvia.net is not your personal blog, so at least try to make it semi-coherent instead of that ridiculous rant at the top of this page.
You're upset, we get it.
This never belonged in Tech Talk.
If you attempt to make a proper review thread, please do so with better grammar then what you have displayed here. No one will take you seriously when you type like a 5 yr old.
ThatGuy is offline
