Old 06-18-2008, 07:23 PM   #1
nismo_drifter
nismo_drifter is on the path to ruinnismo_drifter is on the path to ruin
safc neo install in 95 s14 ka24de...help???
i installed a safc neo in my 95 s14 with the stock ka24de...everything but eothe rpm signal does not work???the throttle position sensor works, the volt meter works, correlation of air flow works, but the rpm on the safc does not work???
i hooked it up to pin #3 on the ecu its the yellow with red stripe and silver rings...is this the right one???i checked the connections and its all good but it does not work???i have my turbo timer hooked up to this wire too...i used the ecu pin out for a obd1 because my friend told me that it was a obd1 and when i searched online i found that 95 s14 comes in obd1 and obd2 so how can i tell the difference???any help please...thanks
nismo_drifter is offline   Reply With Quote
Old 06-18-2008, 07:31 PM   #2
97KATURBOSILVIA
Banned from the Marketplace
Trader Rating: (-1)
97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light
Feedback Score: -1 reviews
just searched. found the rpm signal can be #7 pin not #3. heres the link good luck
http://www.200sx.org/s14-ecu.html
97KATURBOSILVIA is offline   Reply With Quote
Old 06-19-2008, 12:53 AM   #3
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
http://www.240sx.org/faq/articles/95_ecu_pinout.htm
this one is a little easier to read check it out
essforteen is offline   Reply With Quote
Old 06-19-2008, 11:37 PM   #4
nismo_drifter
how do know if my car is a obd1 or obd2???
Old 06-20-2008, 01:19 AM   #5
MangoDorifto
MangoDorifto's Avatar
MangoDorifto is an unknown quantity at this point
if it's a 95, made before 10/95 it's odb1. 10/95-up is 96, which is obd2.
MangoDorifto is offline   Reply With Quote
