Old 06-19-2008, 02:54 PM   #1
S14SwimShark105
S14SwimShark105's Avatar
S14SwimShark105 is making a name for him/her selfS14SwimShark105 is making a name for him/her self
Send a message via AIM to S14SwimShark105
Car Doesn't Start After Being In The Sun
Hey, I was wondering if anyone could help me with this problem I've been having. Whenever I park my car in the sun or on a really hot day, it wont start. It will hesitate to start and then I'll have to sit and wait a little bit and then it'll start, sometimes.
The engine doesn't crank at all, it's as if the battery was dead but all the electronics work, the windows, radio and lights work. If I let the car cool down or it becomes night time it'll start up normally like nothing happened.
This is on a 1996 240sx, hopefully someone knows what could be wrong! thanks in advance.
http://www.amazon.com/gp/prod Amazon book!
S14SwimShark105 is offline
Old 06-19-2008, 03:01 PM   #2
lonelydrifter
lonelydrifter is making a name for him/her selflonelydrifter is making a name for him/her self
That is the strangest thing I have ever heard. Have you made sure all your grounds are good. Could just be a wierd coincidence with the whole day night thing.
lonelydrifter is offline
Old 06-19-2008, 03:16 PM   #3
g6civcx
g6civcx's Avatar
Check starter relay, especially the clutch interlock relay next to the battery. Blue relay bolted to the inners of the fender.
g6civcx is offline
Old 06-19-2008, 03:20 PM   #4
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
+rep for you! thats exactly what i was thinking.
PEGASUS
nismo racer is offline
Old 06-19-2008, 03:22 PM   #5
1slowS13
1slowS13's Avatar
1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice
try pouring cold water on your ignition module, or borrow a friends, it may be bad. see if it starts.
1slowS13 is offline
Old 06-19-2008, 03:35 PM   #6
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
My car was having the same problem.
There are only a handful of big things that can be wrong with it.
Check the small stuff first, no loose connections to the battery or at the starter.
make sure your battery terminals are tight. I'm sure your battery is fully charged and fine.
Check your clutch relay. Sometimes they go bad.
Lastly, your starter might be bad. I replaced everything before I singled out the starter. I had a new batt, new terminals, new clutch relay and it still wouldn't start sometimes. A new starter fixed alllll my problems.
IT IS SO NICE FOR YOUR CAR TO START WHEN YOU WANT IT TO.
Anto is offline
Old 06-19-2008, 04:02 PM   #7
S14SwimShark105
I accidentally left it outside in the sun for a day and I was going to go have it tech inspected for this weekends NASA event at buttonwillow and it wouldn't start
I'll make sure to check all the things you guys said thanks a lot!
Old 06-19-2008, 04:25 PM   #8
g6civcx
g6civcx's Avatar
If you're going to do that, I'd rather use compressed air than water, but that's just me.
g6civcx is offline
Old 06-19-2008, 05:35 PM   #9
S14SwimShark105
awesome problem solved haha thanks a lot guys, i looked at where the clutch pedal was and it seemed that one of the wires were cut or something and it was exposed so i fixed it and it started up normally thanks!
Old 06-19-2008, 05:37 PM   #10
k's_silvia2.0
k's_silvia2.0's Avatar
k's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfection
Send a message via AIM to k's_silvia2.0
HAHA my old explorer use to do this.
k's_silvia2.0 is offline
