Old 06-19-2008, 07:26 PM   #1
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Pblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of light
Feedback Score: 48 reviews
Question nismo clutch line ?
Im doing my five speed swap in a day or two and have a question about the nismo line.
I have the nismo clutch line and the agency power line(removes the dampener). Im pretty sure but am not 100%, the nismo line eliminates the small rubber line that goes from the dampener to the slave right ? And where does the bleeder connector bolt to ?
thanks for the help.
Do you suffer from vaginal dryness...
Pblesh85 is offline   Reply With Quote
Old 06-20-2008, 12:30 AM   #2
projectRDM
projectRDM's Avatar
There's a bleeder on the slave cylinder.
FORMERLY R240NA
Old 06-20-2008, 01:54 AM   #3
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Thats why I was asking, my nismo line came with a bleeder bolt and im not sure where it would go.
Old 06-20-2008, 02:18 PM   #4
mademedoit
mademedoit's Avatar
mademedoit is not welcome here anymoremademedoit is not welcome here anymoremademedoit is not welcome here anymoremademedoit is not welcome here anymoremademedoit is not welcome here anymoremademedoit is not welcome here anymoremademedoit is not welcome here anymoremademedoit is not welcome here anymoremademedoit is not welcome here anymoremademedoit is not welcome here anymore
The agency power line go's from the master all the way to the slave, making it very easy to bleed from the slave cly.. The nismo line is if you only want to replace the small rubber line and keep the steel hard line. So try and sell the nismo line, through away the hard line and ONLY use the a p line.
mademedoit is offline   Reply With Quote
Old 06-20-2008, 06:37 PM   #5
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Ok, thats what I was thinking but was not sure. Thanks for clearing that up.
Old 06-20-2008, 06:38 PM   #6
g6civcx
g6civcx's Avatar
There is one on the stock damper box and one on the slave. Throw away all the stock line and go straight from the master to the slave.
Old 06-20-2008, 06:44 PM   #7
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
my car is auto for another day or two, so i dont think it has all the dampener crap. I was going to delete it anyway.
Anyone need a brand new nismo line ?
Old 07-01-2008, 01:54 PM   #8
Syncade
Syncade is making his/her stupidity well-knownSyncade is making his/her stupidity well-knownSyncade is making his/her stupidity well-knownSyncade is making his/her stupidity well-known
Send a message via ICQ to Syncade
Hey i might actually take that from you for my rb. Does this connect to the first mating block, aka the line that comes directly from the master, does this connect to the end of that, then go directly into the slave?
Aka
Orig: Master -->block-->dampner line-->block-->softline-->slave
Nismo: Master-------------------(hardline)-->Nismo--->Slave
The nismo line will thread into the hardline where it connects to the first block, then thread into the slave?
Sorry to repeat but i just called FR and Vivid and noone really knows the answer and i dont feel like waiting until i return home
Syncade is offline   Reply With Quote
Old 07-01-2008, 02:06 PM   #9
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
If it's this one:
Then yes. It connects to the clutch hardline, and the other end to the slave cylinder.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 07-01-2008, 09:38 PM   #10
Dirty Habit
Dirty Habit's Avatar
Dirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfection
^ I just put mine in yesterday.
Then fried the fuck outta it cause I realize I didnt have an engine ground.
Lol.
1982 280zx Turbo
Dirty Habit is offline   Reply With Quote
Old 07-07-2008, 11:36 AM   #11
SHIFT_*grind*
You fried your clutch line because you don't have an engine ground?
Old 07-07-2008, 02:31 PM   #12
Dirty Habit
Yup. Nothing else was grounded. lol.
Dont ask.
1982 280zx Turbo
