Old 06-21-2008, 01:40 PM   #1
silviaz
silviaz's Avatar
silviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-known
facking timing chain cover...
I'm trying to pull out my lower timing chain cover on my ka24de and I can't! It's not even moving a little......
I pulled out the pulley and the 4 bolt on the top of to upper timing chain, 2 bolts on the oil pan and the rest of the bolt that the fsm is showing on the first page of the timing chain section. I've noticed a stange little head nut on the left.. but if it was only that ,It would move......(just a little screw on the top of the oil pan..)
I'm keeping the thermostat and the water pump on the front cover......
Any ideas ?
silviaz is offline   Reply With Quote
Old 06-21-2008, 01:45 PM   #2
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Ya gotta pull the oil pan off of the motor enough to get the pickup tube unbolted... and pry the shit out of it.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 06-21-2008, 02:01 PM   #3
silviaz
silviaz's Avatar
ok thanks! I'll remove that oil pan.
Do you know what is that little bolt on the left and the right of the lower timing chain cover... the bolt look so tiny... I have no clue what type of tool I need.
Old 06-21-2008, 02:07 PM   #4
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
hahaha. I did the same thing. I was ready to hit the motor with a sledge hammer due to frustration of having EVERY bolt out, yet it wouldn't budge.
Depending on the year motor, as stated above, the oil pickup is connected to the front cover. Drop pan, remove pickup bolts, done.
gotta240 is offline   Reply With Quote
Old 06-21-2008, 02:16 PM   #5
silviaz
silviaz's Avatar
hehe gotta240, you feel my pain too.
I took a picture of the strange bolt I didn't remove yet. I don't know what to do with them cuz I don't have that strange tool with me... I hate my car with a passion right now.
Old 06-21-2008, 02:22 PM   #6
gotta240
hang on. i'm going to look at mine now.
edit. Those are allignment dowels that are stuck in the block. they just hold the cover in proper position. Don't try to take them out.
Just remove all the bolts, oil pan, oil pickup, and it will pop off.
Old 06-21-2008, 02:25 PM   #7
silviaz
silviaz's Avatar
thx I LOVE YOU lol
+rep 1 billion points
Old 06-21-2008, 02:27 PM   #8
gotta240
haha. no worries. I just took two of them appart in the last few weeks. Let me know if you have any more questions.
Old 06-21-2008, 09:16 PM   #9
silviaz
silviaz's Avatar
Ok I have a problem...... I removed the two bolt on the pick up tube and the cover don't want to go off the engine. I'll upload some picture soon.
Old 06-21-2008, 09:26 PM   #10
silviaz
silviaz's Avatar
Here's a better view of what I did today...
I don't know if I should remove the two other bolt on each side of the lower timing chain.
Old 06-21-2008, 09:28 PM   #11
97KATURBOSILVIA
Banned from the Marketplace
Trader Rating: (-1)
97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light97KATURBOSILVIA is a glorious beacon of light
Feedback Score: -1 reviews
Spray lube on crank pulley it may be ceased to metering oil gear, and yes pics are now needed make sure you take pics of upper and lower of what u removed so far.
HEY THERE IS A BOLT BEHIND THE DISTRIBUTER (ACTUALLY TWO OF THEM) SO ONE GOES DOWN INTO BOTTOM COVER IT IS A 10MM DID YOU REMOVE THEM
oh yea almost forgot the pcv come off with the bottom cover you have to disconnect the water hoses and pcv breather hoses from the back did you do that also
97KATURBOSILVIA is offline   Reply With Quote
Old 06-21-2008, 09:42 PM   #12
silviaz
silviaz's Avatar
I removed so far:
All the bolts attached to the lower timing chain cover, I kept the water pump and the thermostat.
I removed the alternator braket
the crank pulley has you can see.
the oil pan.
the oil pickup tube (3 bolts total)
A vaccum/tube behind the thermostat.
Some people told me it was not necessary to remove the upper timing chain cover.... that's why I'm keeping it.
Maybe I did everything...but that cover is pretty hard to remove... fuck!
Old 06-21-2008, 10:04 PM   #13
97KATURBOSILVIA
Trader Rating: (-1)
you missed a 12mm behind the wayer pump pulley take off the pulley its on the left and not part of the water pump housing, i can see it still there in the pics if it is part of the water pump housing just remove the water pump for sake. crap just take the top cover off as well u are missing something i just did a rebuild yesterday and it looks as if you got it but obviously u missed something
Old 06-21-2008, 10:06 PM   #14
silviaz
silviaz's Avatar
The damn cover is now moving!!!!!!!!!!!!! i'll be back
Old 06-21-2008, 10:12 PM   #15
97KATURBOSILVIA
Trader Rating: (-1)
AHHH progress and for the love of 240's get some engine degreaser FTW
Old 06-21-2008, 10:30 PM   #16
silviaz
silviaz's Avatar
i removed the water pump it has nothing to do with the cover but its ok. the cover is now 1/4inch off. i'll need the help of someone cuz it looks glued haha.
Old 06-21-2008, 10:50 PM   #17
silviaz
silviaz's Avatar
It's 1:00 AM, i'll update this thread later on sunday for the progress.
Old 06-21-2008, 10:50 PM   #18
97KATURBOSILVIA
Trader Rating: (-1)
Keep at it work it back and forth, it should have gasket maker on it like rtv blue or black. GL
Old 06-21-2008, 11:45 PM   #19
LA_phantom_240
I assume you also took he upper timing cover off as well? I'm pretty sure you need to take that off. Don't quote me on that though. Ive always had it off already before tackling the lower cover lol.
Old 06-21-2008, 11:47 PM   #20
gotta240
Thats what i said. I don't think its necessary, but it def. makes things easier and lessens the chance of missing a bolt.
If i were you, i'd remove distributor, remove upper cover, then lower cover.
Old 06-22-2008, 07:46 AM   #21
s14coastie
s14coastie's Avatar
s14coastie will become famous soon enoughs14coastie will become famous soon enoughs14coastie will become famous soon enoughs14coastie will become famous soon enoughs14coastie will become famous soon enough
You probably got it out by now but, if not, did you remove these bolts behind the distributor??
s14coastie is offline   Reply With Quote
Old 06-22-2008, 08:16 PM   #22
silviaz
silviaz's Avatar
Finally the job is DONE! There was no missing bolt......... I feel soooo stupid.. It was only very, very well sealed I could not believe it. I used a mastic knife and a hammer between the cover and the bloc and it moved after that! Now, the engine is ready to drop, there's no more oil on the engine so 97turbokasilvia will be happy ! lol I can lick my engine now!
There's only a bad thing I did...... I didn't want to remove the upper timing chain cover... I just hope it'll not leak from the top... I'll be able to tell you if the job is perfect this week.
Old 06-22-2008, 08:22 PM   #23
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
yea that really good seal.... that was the front portion of the head gasket holding it on
hope ya didnt fuck that up.....
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 06-22-2008, 08:35 PM   #24
silviaz
silviaz's Avatar
I know there's one bolt missing on the pulley. I'm just waiting the proper tool to bolt it with the right spec.
Old 06-22-2008, 08:37 PM   #25
koukimonster139
lol
yes!
gasket maker
ho ha ho chi chi
Old 06-22-2008, 09:13 PM   #26
97KATURBOSILVIA
Trader Rating: (-1)
looks yummy good job, now pat your self on the back and go driving
Old 06-22-2008, 09:22 PM   #27
projectRDM
projectRDM's Avatar
I hope you:
1) replaced the hat seal
2) didn't go as crazy on the timing cover as you did up top on the head gasket with RTV
I've seen three engines fail due to low oil pressure from people gooping so much RTV that they block the oil passage into the block from the oil pump. First startup, brand new parts or timing kit, 10 minutes later they've got shredded bearings.
FORMERLY R240NA
Old 06-23-2008, 09:31 AM   #28
silviaz
silviaz's Avatar
Thank you project RDM for the neg. I didn't go crazy on my silicone except on the top. I respected the 3mm to 5mm passage on the rest of the cover. I'm not as bad as you think. I'll clean that thing off.
On the rest of the cover, it's very clean, even the oil pan is looking perfect.
Old 06-23-2008, 11:30 AM   #29
LA_phantom_240
Don't get butthurt over neg reps. They happen, trust me. Oh and unless he actually put his SN in the neg rep (which I do for non-premies, neg or pos.)... then yeah.
But yeah, RDM the same thing happened to my friend's s13 motor. Old man who owned the car last went muy loco with the RTV... Spun two bearings. Sucks.
