Old 06-23-2008, 11:20 AM   #1
bfeng24
bfeng24's Avatar
bfeng24 is not welcome here anymorebfeng24 is not welcome here anymorebfeng24 is not welcome here anymorebfeng24 is not welcome here anymorebfeng24 is not welcome here anymorebfeng24 is not welcome here anymorebfeng24 is not welcome here anymorebfeng24 is not welcome here anymore
Boost Stutter?
I have a 240 with an sr20 swap, it drives ok, when i reach higher rmps in each gear it seems to stutter (around 7-10 psi), its not really a hesitation. I just replaced the maf with a z32 but that did not help. Any suggestions?
Thanks
bfeng24 is offline   Reply With Quote
Old 06-23-2008, 11:31 AM   #2
turns101
turns101's Avatar
turns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond repute
Send a message via AIM to turns101
Get back to the basics
Plugs, wires, timing
Fuel filter
air filter
Check all of that forst.
Are you having any CEL codes?
-Jeff Abbott. Big white guy, little green car. late spooler
turns101 is offline   Reply With Quote
Old 06-23-2008, 11:51 AM   #3
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
when you swapped in a z32 maf, did you do anythign to compensate for the different pinning ?
but what was already stated, start with the basics. sounds fuel or timing related.
clark is offline   Reply With Quote
Old 06-23-2008, 12:04 PM   #4
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
sounds like you're blowing out spark. lower the plug gap to .028 you should be running an ngk bcpr7es or bkr7e.
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 06-23-2008, 05:18 PM   #5
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
Sounds like either a boost leak or spark blow out.
SuicidnS13 is offline   Reply With Quote
Old 06-23-2008, 09:17 PM   #6
DirtyS14
DirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enough
Dave
Yep thats exactly the problem I had. Plugs were too hot. I put in some bkr7e plugs and problem went away, runs great now.
Definitely try getting some colder plugs.
S14 240SX aka "The Dirty S14"
fizzerkart.com/s14.html
DirtyS14 is offline   Reply With Quote
