HELP ME! car will only push start!
sorry i know there are a lot of threads about the key turning and nothing happening but i didn't find much help for my case.
so it was just out of no where i tried to start my car and it was cranking and then just stopped. its not a battery problem. i have a new battery and tried jumping the car. now when i turn the key the only thing happens is the little click sound where the fuse box is next to the dead pedal. but whats weird is that i can start the car if i push start it . . . . someone help me please!!! |
#4 | |
![]() Join Date: Apr 2007
I know this has been covered before on the forum. Sometimes its easier finding what does work so we can help you to pin point what doesnt.
Team Inertia Cheap,Fast,Reliable you can only have 2. |
I'm not home so i don't have access to any of my schematics or id look for you. Im in japan and dont know when ill be home. Probably not for another week or so but it sounds like your getting power to your ignition relay but not to the starter. By you being able to push start it tells me its somewhere between the key and the starter. First thing i would do is ensure no wires disconnected from your starter. Try looking in a wiring schematic and see what is between the ignition and the starter. Could be something as simple as a disconnected wire or a bad relay/fuse under the hood. Just use a schematic to see what could stop power from getting to your starter and isolate it from there. Wish i were home so i could give you better ideas of what to check but maybe this will help. Good luck with getting it started.
![]() Join Date: Jun 2006
starter/starter solenoid(sp?)
had the same problem on my car. try hittin at the starter with a stick and than starting it
lexus baby |
![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Sounds like the starter but if your battery does not have full charge it will do the same thing. Deff. sounds like the starter but make sure your battery has a full charge, even check the terminals make sure they are geting a good connection... Good luck
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
my buddy had the same problem - turns out that a small guage wire that supplied power fell off - look close @ the starter for loose wires/plugs - took him a while to find the wire
![]() Join Date: Sep 2006
Check to see if the little plstic piece is still in your clutch pedal. Mine broke and the car would not start when clutch was in because the little button wasn't depressed.
This happened to me before, there is a spade connector on the solenoid check for that. Its kind of hard to see whats going on but if you feel it its pretty obvious and also check for unplugged wires. hope that helps
Oh jeeze, this problem is the same problem I had the first day I got the car. Check to see if everything on the starter is tight. I blew a fuse and for some reason at the same time the alternator cable blew off. Everything would work, I would hear a click, but no cranking.
#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
check the switch on the clutch pedal. has the car been doing it since you got it? or it just happened? it may also be, that the alarm has failed and is preventing power towards the starter.
#16 |
![]() Join Date: Oct 2003
ah...and another thing. make sure the connection to the battery is as tight as reasonably possible and that your ground wire is connected correctly.
and like one of the previous guys said, check the wiring for your clutch safety switch (plug located behind clutch pedal)...had mine bypassed and one time it came loose from the butt splice and it gave me the same issues that you're having right now
![]() v-mount ftmfw. |
#17 |
![]() Join Date: Jun 2007
Thats the starter solenoid. Your gonna be better off buying a new starter. Trust me, Its happend to me about 6 times.
OR... you could get a starter adjustment tool. ( A HAMMER) tap the starter a few times, then see if it'll kick over.
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
#19 |
![]() Join Date: Jul 2007
it's your battery.
try jump starting your car, same thing happened to me. i tried cranking it and i would hear the little ticking noise by the fuse box by the dead pedal. pushed started it and it worked. but i wouldnt start normally. i thought it was my starter but i just got that replaced about a month ago when it happened. tried jumper cables and it started right up. went to get a new optima battery, works great everytime now. ![]() |
#20 |
problem solved. thanks everyone. nothing would work so i just disconnected everything put it back together it started but the crank sounded so weak so i just decided to replace the starter.
#22 |
kouki man
![]() Join Date: Apr 2006
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
pull out your VOM/DMM then check see if you are getting 11volts or higher on the hotwire connected from the alternator/battery. i had this problem last week and i ran out of 2 starters then replaced them. then check and cleaned/replaced my battery terminals. check ground
#24 |
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
same here but mine seems to be fast ass clicking coming near the front of my car near the battery my guess its that blue relay posted on the fender lol but jigglin the key up and down as i start the cars works try that might be igniton switch long shot but you cant rule it out
battery voltage battery connection +/- terminals do you have corrosion on the post? voltage drop when you start the car dead cell with in battery? |
#25 |
![]() Join Date: Apr 2008
Location: lost in a bump splice in the fabric of our clockwork
this happened to my homie a while ago
try pushing down really hard on the clutch pedal there is a starter relay switch under it if that doesnt work then just put the car in neutral and put your left foot under the clutch pedal and depress the switch if it works then you owe me ![]() |
