![]() I used the search function but I have only found Rear STB's for the s14 that go over the deck lid. The car came with aftermarket speakers that are quite high up, so I need a Rear STB that will mount under the speaker deck lid. I want to avoid cutting into the strut wells. Are there any companies that manufacture a lower rstb?
Nico |
![]() Join Date: Mar 2002
to be quite honest, i dont think they'll do anything. i mean, the wheels are already spinning from there. the front helps tho, i dont see how the rear would. someone correct me if i'm wrong.
#3 | |
![]() Join Date: Sep 2002
Re: S14 Rear STB
Keeping it Godzira bishes. So I murdered another turbo |
#6 | |
Yes, I look like that
i have cusco OS. no problems at all.
http://bhworld.wordpress.com/ |
Would that be a safe place to mount a harness from?
Damn gettin down with the chemistry. Thanks a lot. I have a little bit of clearance from the speaker to the glass, so I can possibly mount a bar that goes over the decklid. I'd appreciate it if someone measured the clearance of their bar from the glass, it would help a lot. Do you have to drill anything to fit the cusco bar that goes under the decklid?
Nico |
![]() Join Date: Nov 2002
No drilling or modifications are required for any of the rear STB that go under the decklid (i.e. in the trunk area). Actually, there is a small opening allowing access up into the strut tower areas (almost as if Nissan had designed it for the aftermarket to make it more accessible).
On bars that go over the decklid (i.e. above speakers or inside the cabin), some modification to the decklid is required. Really just depends on what bar you go with and what you prefer to do? Do you really need that little extra area in the trunk? Or do you prefer to modify the decklid and show off to everyone from outside the car that you have a STB? Tim '95 SE |
#11 | |
yes there is plenty of clearence for the speaker with the lower bar.. ant the upper bar too. R240NA runs both the only cutting is the decklid cover for the upper bar
#13 | |
To everyone else: don't let that change your plans, Russ is anal about weight and your speakers will, in fact, fit. |
#14 | |
#17 |
![]() Join Date: Jan 2002
yeah i got the nismo rear strut bar and it goes over the rear speaker panel. the only modification that u need to do to make it fit is cut two slits on each side of the rear speaker panel so that the braces for the strut tower bar stick up through it to attach the bar itself. if u do a search i think grant posted up some good pics of what the bar looks like above the rear speaker panel
95 240sx SE,custom dual apex n1, 17" rims,tanabe sustec front STB,nismo rear STB,intake,tanabe sustec pro coilovers,autometer guages, soon to have stock 97-98 side skirts and rear mud guards and bomex drift wing ![]() ![]() |
