Old 06-30-2008, 12:43 PM   #1
TFOD_2007
TFOD_2007 is an unknown quantity at this point
How to remove trunk light from S14 trunk ?
Hello Zilvia , it seems fairly simple but I can't remove it . I removed the 8mm nut from each side , but the center section won't budge .
Can anyone give me advice on how to remove this light ?
Thanks
TFOD_2007 is offline   Reply With Quote
Old 06-30-2008, 01:48 PM   #2
coreansurfer
coreansurfer's Avatar
coreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfection
gently but firmly pull it off, there should be a sticky sealant on there to prevent water from getting in to the trunk
Originally Posted by avs0730 View Post
if I stupid why is people pm about the car
coreansurfer is offline   Reply With Quote
Old 06-30-2008, 02:01 PM   #3
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
a hair dryer on hot or a heat gun helps big time. be very careful, i cracked the black trim part when i took mine out.
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 06-30-2008, 03:39 PM   #4
mrmephistopheles
mrmephistopheles's Avatar
you can use a razor to cut away the stuff holding the lamp to the trunk
Originally Posted by PHLIP
Old 06-30-2008, 04:37 PM   #5
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
if brute force doesn't work...... you're not using enough of it.
Tenchuu is offline   Reply With Quote
Old 06-30-2008, 04:38 PM   #6
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
Make sure you got all the nuts off and push harder lol
WangonwWarrior is offline   Reply With Quote
Old 06-30-2008, 04:43 PM   #7
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
needle and threadin the crack
bigOdom1 is offline   Reply With Quote
Old 06-30-2008, 09:47 PM   #8
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
Yup.
there is some weird stuff holding it to the trunk on the inside besides the screws.
cut it.
Sir is offline   Reply With Quote
Old 06-30-2008, 09:51 PM   #9
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
LOL! "get the nuts off and push harder"!!!!!! Effin classic right there!
