Old 06-30-2008, 02:42 PM   #1
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
brake fade?
Im using the pbr xbg semi metallic brake pads with q45 calipers and using hawk hps in the rear with stock calipers. When i brake hard at higher speeds it feels as if the brakes fade easily. I bled the system countless times with a speed bleeder. Could the PBR brake pads be causing this? I dont see much people using it so im not sure if its good quality ones.
SilviaSR20DET is offline   Reply With Quote
Old 06-30-2008, 02:56 PM   #2
calico
calico is making a name for him/her selfcalico is making a name for him/her self
the xbg pads are lower in performance compared to the hps pads. i would say the pbr ultimate (axxis ultimate) pads are near the same performance level as hps. the ultimate pads are better than the xbg's when comparing the different models of pbr brake pads
calico is offline   Reply With Quote
Old 06-30-2008, 02:58 PM   #3
calico
so... i would say yes, the problem could be the pbr brake pads
sorry, didn't realize i didn't actually answer your question in my previous post
Old 06-30-2008, 07:49 PM   #4
SilviaSR20DET
thats what i thought, because at lower speeds it brakes pretty good but at higher speeds it loses its braking power. Thanks for the heads up and next time ill stick with all the same brake pads and ditch the pbr's.
Old 06-30-2008, 07:58 PM   #5
norbac
norbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant futurenorbac has a brilliant future
so axxiss ultimates are good? (sorry for thread jacking)
norbac is offline   Reply With Quote
Old 06-30-2008, 08:06 PM   #6
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
That's exactly why I don't wanna do the q-45 front brakes on my car. There are no true race pads available for them. HPS's in the front would be much better and I know a lot of guys that swear by the axis ultimates, but in the end they are both weaksauce for track useage. For street just slap some HPS's or axis ultimates on the front and you'll be good. I personally don't like to run mis-matched front and rear brakes though.
Old 06-30-2008, 08:08 PM   #7
JohnJohn86
JohnJohn86's Avatar
JohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura about
Get Porterfield pads. No fade for me even in Buttonwillow Raceway
JohnJohn86 is offline   Reply With Quote
Old 06-30-2008, 08:10 PM   #8
racepar1
racepar1's Avatar
Porterfield makes pads for the q-45 calipers? If so I will re-consider putting the q brakes on.
EDIT: I just checked and porterfield only has the r-4s pads, which is their "street" version. Still almost certainly superior to any other pads mentioned in this thread. For all-out track useage I think it would be better to source a set of ABS s-13 calipers and slotted rotors with the porterfield r-4 pads and some brake ducts.
Old 06-30-2008, 08:23 PM   #9
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
http://www.horsepowerfreaks.com/perf...kes/Brake_Pads
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 06-30-2008, 09:40 PM   #10
SilviaSR20DET
i think EBC has race pads for the q45, so it seems like theres quite a bit of selections from what i know so far.
Old 06-30-2008, 09:42 PM   #11
racepar1
racepar1's Avatar
Originally Posted by MrChow View Post
NOT race pads!
I dunno if I would trust EBC "race" pads.
In either case the porterfield pads would be far superior I believe.
Old 07-01-2008, 02:46 AM   #12
tgd89
tgd89 is on a distinguished road
Exactly what sort of fade are you feeling? A soft mushy pedal, or a hard pedal that doesn't go down? Could be fluid choice, do you have the damper box still hooked up? It could be keeping some air in the system.
tgd89 is offline   Reply With Quote
Old 07-01-2008, 07:56 AM   #13
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
yea what fluid?
97 240sx se
0wn3r is offline   Reply With Quote
Old 07-01-2008, 09:42 AM   #14
JohnJohn86
JohnJohn86's Avatar
Their street version is more than enough for a N/A KA engine or stock Sr20 IMO. I never had fade no matter how hard I brake.
You can call up portfield and order their race compond. It shouldn't cost that much more.
Old 07-01-2008, 10:16 AM   #15
boozels
boozels's Avatar
boozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to all
porterfield's are the shit
R4-S are great for the street and can handle any track day anytime!!
you can't go wrong with porterfileds
t-apc.com t-apc.com t-apc.com t-apc.com
boozels is offline   Reply With Quote
Old 07-01-2008, 01:31 PM   #16
SilviaSR20DET
Feels a bit soft mushy when it starts to feel like its fading. Im using valvoline synthetic brake fluid. I didn't delete the dampner box, where is it located? But it locks up fine at lower speeds, just that the higher the speed and braking hard, i feel fade.
Old 07-01-2008, 01:33 PM   #17
SilviaSR20DET
Oh and i forgot to mention that my BMC was leaking in the past and the brakes prior to the q45 conversion had the fading problem.
Old 07-01-2008, 01:56 PM   #18
aznrib
aznrib is making a name for him/her selfaznrib is making a name for him/her selfaznrib is making a name for him/her self
I bought my q45s from frsport with r4s pads and r4 pads made by porterfield. No fade so far.
aznrib is offline   Reply With Quote
Old 07-01-2008, 04:22 PM   #19
racepar1
racepar1's Avatar
Try different fluid too. On a buget I like the castrol GT LMA fluid. We used it on our formula atlantic cars for YEARS without problems. There is no dampener in the brake system, just in the clutch system. The guy who gave you that info in this tread was smoking some shit!
Old 07-01-2008, 11:35 PM   #20
SilviaSR20DET
okay ill give that fluid a try and new brake pads when these wear off. I was about to say that there is no dampener box because the only one i remember taking off is my clutch dampener haha!
Old 07-02-2008, 06:49 AM   #21
McCoy
McCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of light
When was the last time you bled your brakes? I've been using the Valvoline SynPower for 5 years now and have yet had fluid boil while on track... and the track I run on is one that is not easy on brakes.
McCoy is offline   Reply With Quote
Old 07-02-2008, 12:18 PM   #22
SilviaSR20DET
i bled it like 2 months ago when i changed my stock front brakes to the q45 brake calipers. Do you guys think its my bmc? Or possibly a faulty rear caliper because i had a hard time turning the piston back in and the rubber cover is stuck.
Old 07-02-2008, 01:42 PM   #23
steve shadows
steve shadows's Avatar
Yeah Im trashing my Hawks and going BACK TO porterfields soon
Like Me on FaceBook !
