Old 03-12-2003, 04:35 PM   #1
haah
haah is an unknown quantity at this point
would it be possible to change the suspension myself ?
so would it be possible ?
what equipment i need ?
how do i compress the spring ?
how do i install a absober ?
haah is offline   Reply With Quote
Old 03-12-2003, 04:39 PM   #2
Dousan_PG
Dousan_PG's Avatar
its a very simple job
but if you dont know how to do it, i dont suggest it (or have a friend who knows what they are doing to help you, its good to know how and learn it)
basically, if you are changing it, you need a spring compressor, basic tools (sockets etc) and a torque wrench (to torque it down to spec).
you can rent a spring compressor at most auto parts stores for a deposit and a very small fee.
basically compress spring, unbolt and remove spring, decompress slowly.
and its just the opposite putting the new spring on the new shock. compressing, then bolt top back on, bolt into car, torque down to spec
GET AN ALIGNMENT (very important)
i think that's it in a nut shell
Aaron
Pink GodziRa
Old 03-12-2003, 06:10 PM   #3
THX1138
THX1138 is an unknown quantity at this point
Check in the install section here and on 240sx.org and you'll find several write-ups folks have made, describing strut/spring installations in obscene detail. Get a few of these, print them out, read them several times, and keep them handy while you're doing the work. Many of them mention common trouble spots and suggest ways to solve the problems.
THX1138 is offline   Reply With Quote
Old 03-12-2003, 11:35 PM   #4
haah
wow
thanks a lot for the information
Old 03-12-2003, 11:48 PM   #5
ygblat
ygblat is an unknown quantity at this point
Send a message via AIM to ygblat
just curious, are you replacing the stock with an aftermarket one and if so, which one? (looking for ideas for myself).
ygblat is offline   Reply With Quote
Old 03-12-2003, 11:50 PM   #6
haah
i haven't bought one yet
but i am thinking of kyb + eibach spring
Old 03-13-2003, 12:14 AM   #7
MorganS13
MorganS13 is an unknown quantity at this point
have fun gettin those lower bolts off i changed mine when i worked at an infiniti dealer so i had access to a lift, spring comressor, air tools, etc... i don't know if i could've gotten those bottom bolts off at home, they didn't wanna budge from being rusted so much, i'm surprised i didn't strip/snap off the heads with the air wrench
MorganS13 is offline   Reply With Quote
Old 03-13-2003, 07:58 PM   #8
THX1138
Don't remind me, Morgan. Despite having all the tools and the help of a pal who'd swapped the springs on his S14 just a few weeks earlier, my AGX/ProKit install could hardly have been worse. The nuts on top of both front strut/spring assemblies were cross-threaded from when I had stock-replacement struts put in a few years ago. Stupid Sears. One stripped the threads off the shaft as it came off, the other never let go and the shaft sheared off!
Damage done during front install: 4 broken Vise-Grips, one shattered screwdriver handle, ~276 scratches in concrete driveway, ~276 curse words uttered.
Then those frickin bottom bolts on the back wouldn't budge; we broke a breaker bar trying to get them off and I had to get them loosened by the mechanic when I had the AC compressor replaced a few days later. Once that was done the rears went in super-easy.
But don't get discouraged, haah. As long as things aren't corroded too badly or some fool didn't cross-thread or overtighten something when the dampers were replaced the last time, it'll just be a few hours of fun hard work.
