Old 03-15-2003, 06:55 PM   #1
black180sx
black180sx is an unknown quantity at this point
89,90 factory lip
How do you mount the 89,90 factory lip on 91-94 240sx? Did u remove the brackets? use double sided tape? use twist ties?
thank you,
jordan
black180sx is offline   Reply With Quote
Old 03-15-2003, 09:10 PM   #2
knightrider
knightrider's Avatar
knightrider is an unknown quantity at this point
i dont think you can, the 89-90 lip doesnt look like it would fit on a 91-94, although i have never tried, i dont think the 91-94 front end is flat, like the 89-90. hey whoa, ur name is jordan too
Drift_ Into A Mountain
Jim Wolf Technology
Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu
knightrider is offline   Reply With Quote
Old 03-15-2003, 09:18 PM   #3
AKADriver
AKADriver's Avatar
It does "fit", I've seen it done. It's not an exact fit, but good enough.
But I'm not sure how it installs. I know people who use the '89-'90 lip on Silvia front ends just zip tie it on.
Old 03-15-2003, 09:41 PM   #4
Dousan_PG
Dousan_PG's Avatar
bolt holes dont match up for the 89/90 on the 91+ bumper. i just zip tied mine all over. looks fine and still on there..for now
Aaron
Pink GodziRa
Old 03-16-2003, 02:01 PM   #5
mrmephistopheles
mrmephistopheles's Avatar
I drilled holes through the lower portion of the stock DOHC bumper to fit the bolt ends on the attaching bracket through. I then mounted the lip, placed the lower bracket under the lip mounting portion, and tightened down the nuts. Works perfectly. For the sides, I just used a screw to secure it to the bumper.
-Kevin
