![]() Join Date: Dec 2003
Oil Pressure Guage Hook Up
Where on the SR block can I hook the oil pressure guage up to? Also, will this threaded bung thing work, or will I need to buy an adapter? Thanks!
-John |
Man w/ CTSV & a Car Seat
Depends on the Gauge...Im running Greddy and i ended up using their oil relocation kit for a clean install *theres holes in there where the sensor will just plug into*
![]() Join Date: Nov 2002
Autometer plugs right into the dumpster. HAHA. Sorry, i don't trust autometer.
Anyways, the GReddy Sandwich oil filter plate should work fine, i think oil pressure seonsors may b universal fit. But then again, i dunno, Autometer is an American company. Email [email protected] and ask him, he may know, or find out. If you know your autometer's sensor thread pitch and size, im sure that would help a lot too. |
auto meter water temp sensor is 1/8 NPT -27 im willing to bet oil pressure is the same... i can check tomorrow i have both the gauges and sensors sitting in my garage...
but the GReddy stuff is probably 1/8 BSPT you will either need a NPT -27 to BSPT adapter, or tap one or the other out. i had to tap my water temp unit to accept the autometer sensor, i may tap out my oil filter sandwhich plate too when it comes down to time to install my oil pressure gauge. ![]() hope this helps... |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
www.mcmastercarr.com has an adapter from 1/8 bspt to 1/8 npt take out your oil pressure warning switch and thread it in there
I never knew you could do that with an eggplant |
#7 | |
![]() Join Date: Dec 2002
the nicest thing about this is you pay like 2.00 shipped for the adapter instead of over 100 for the greddy part
#9 | |
If you have oil cooler, you can measure it that way.
92 FastBack - Project 98 SE - Daily Driver |
#10 | |
![]() Join Date: Jun 2004
Anyhow, I have a greddy unit, and I called them about the NPT vs. BSPT deal...Greddy senders are NPT. A SR20 block is BSPT...you need a small adaptor if you are doing away with the stock unit...which I will be doing. Peace.
S14 Zenki...SOLD!! New Project: 240Z w/ SR |
#11 | |
I you should try it out before getting the adapter. I think their senders are BSPT and they dont know the difference.
#12 | |
#14 | |
would this be the one?? http://www.autometer.com/cat_accesso...il.aspx?vid=59 |
#15 |
#17 | |
you can also look up tunertoys.com the duel feed oil adapter so u can keep oem sensor just in case |
#18 |
Why? Because you like having an inaccurate sending unit that is guaranteed to leak?
I'd rather run without anything than to have the OE sending unit.
#19 |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
I installed my autometer oil pressure gauge, its easy, get that part from mcmaster carr that was mentioned, but you'll also probably need iirc, a 45 degree adaptor for it because when I installed mine I had clearance issues with the sender unit facing vertical. I'll try to get the part numbers to those parts from mcmaster and I'll post it up.
#20 | |
#21 | |
at lease if the light comes on it catches my eye (when im looking ahead) and i can shutoff mabe ill get lucky and save it y not for 20 bucks? also check out parker fittings they should have it for a few bucks if you have it locally |
