Old 07-07-2008, 10:29 PM   #1
Psycho 240 Freak
Psycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-known
Could this be a bad turbo?
HKS GT2530 on a S13 SR20 @ 17 psi
Symptoms:
1. Makes a grinding like sound from the turbo when I hit full throttle
2. Does not build boost but I didn't keep my foot on the gas for too long either
3. Blue smoke came from around the turbine and turbo elbow area, once that I noticed
4. After hitting full throttle for about a second and the rpms drop back down, the turbo would make a grinding noise for about a second
5. Rattling noise coming from the turbo during idle and normal driving
Things I've already checked:
1. Turbo is not loose from the manifold or elbow
2. All hoses are secure and tighten
3. Shaft play about 1 to 2 mm
4. Turbo spins freely
Anything else I should check? So do you guys think the turbo's done? I need to be sure before I go out and get a new one.
Psycho 240 Freak is offline   Reply With Quote
Old 07-07-2008, 10:35 PM   #2
Clowny
Clowny's Avatar
Clowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to behold
Send a message via AIM to Clowny Send a message via Yahoo to Clowny
is the shaft play side to side, front to back, or both?
Clowny is offline   Reply With Quote
Old 07-07-2008, 10:39 PM   #3
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
thats alot of shaft play man...
SexPanda is offline   Reply With Quote
Old 07-07-2008, 10:52 PM   #4
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
that turbo is shot,
if there really is 1 to 2 mm of shaft play it is defiantly done past the point of a rebuild probably.
shaft play should be in the .05 of a mm .
sr20boostn20 is offline   Reply With Quote
Old 07-07-2008, 10:54 PM   #5
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
turbo needs rebuild. though, check to see if the turbine has hit the inside of the outlet
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 07-07-2008, 11:27 PM   #6
Psycho 240 Freak
It's side to side. I should've checked front to back to but didn't. I'll do that tomorrow.
Old 07-08-2008, 05:20 AM   #7
Sileighty_85
Sileighty_85's Avatar
Dont Bother Its toast, Rebuild it
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-08-2008, 05:34 AM   #8
jsasrsr
jsasrsr's Avatar
jsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of lightjsasrsr is a glorious beacon of light
Send a message via AIM to jsasrsr
trash it... you can try to send it to blaast and get it rebuilt, but holy crap 1 to 2mm, its probably finished with its useful life...
jsasrsr is offline   Reply With Quote
Old 07-08-2008, 05:56 AM   #9
shmiddy
shmiddy's Avatar
check for oil down the exhauhst pipe, also see if any of the fins are cracked.. my sr stck turbo was shitted and those were some signs that i saw
i fully de-volved
Old 07-08-2008, 02:01 PM   #10
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
This is like a 200 lb boulder falling on your arm and you look at your arm and see your bone sticking out and asking us if its broken.
Either way, just get it rebuilt.
Slap on a t25 if you need to get around.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
