Old 07-09-2008, 11:57 PM   #1
mikeyyy
mikeyyy's Avatar
mikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to allmikeyyy is a name known to all
s14 turn signal help!!!
i was in the middle of driving and my turn signals LITTERALLY just stopped working. when i got home, i changed to brand new fuses but it still wouldnt work. On top of that, my hazards became out too. The rest of my lights still work though. (headlights, taillights, brake lights)
any ideas?
mikeyyy is offline   Reply With Quote
Old 07-10-2008, 12:09 AM   #2
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
look for continuity either ground or power wire for that light all your lights work so dont worry bout them just single out that one harness. if you disconnect hazard switch you lose both turn signals it might be a malfunction with in the hazard switch look for a spare or a known working one plug in and see if turn signals work if not its the harness connecting to tha hazard switch that is at fault PM me if your lost hope that lil bit of info helps
S-Nation S13 is offline   Reply With Quote
Old 07-10-2008, 12:13 AM   #3
Mikey88
Mikey88's Avatar
Mikey88 is on a distinguished road
have you checked your blinker fluid? jp lol check the combination flasher unit or check the hazard switch itself you must have an open somewhere in that circuit.
Mikey88 is offline   Reply With Quote
Old 07-10-2008, 12:25 AM   #4
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
Agreed check your hazard switch.
and the fuse to that.
It dominoe's to the turn signals.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 07-10-2008, 08:02 AM   #5
projectRDM
projectRDM's Avatar
Or check the flasher, it's more prone to go out than the hazard switch.
FORMERLY R240NA
Old 07-11-2008, 12:58 AM   #6
mikeyyy
mikeyyy's Avatar
okay so if i get my hazard light fixed, it should fix the turn signals as well? because the turn signals dont work inside or outside (i hope that made sense)
but i guess ill check the flasher relay and let everyone know how it goes
Old 07-11-2008, 01:17 AM   #7
downshift_sideways
No Limit Soldier.
Trail and error.
report back then.
